Stubborn Brake Light Problem
Old Dec 27, 2019 | 08:02 PM
Enmanuel09's Avatar
Unhappy Stubborn Brake Light Problem
Hi there. A couple weeks back my right brake light stopped working. Since I've been using LED's for almost 1 1/2 year, I thought it could be an issue with them being LED's. So I kept the old halogen and replaced both, but still it would not light up. Oddly, then I swapped the left bulb with the right bulb and now the left brake light would not light up. I reversed the swapping and since then, I've had the right brake light not workiing. Thinking it was the brake light switch, I went ahead and what looked to me like a damaged switch, got the new one and replaced it. After when testing, the right brake light still does not light up. In my opinion, the bulb type does not matter LED or not. Any ideas of anything else that could be, besides the brake light switch? Thank you!
Old Dec 28, 2019 | 11:01 AM
Default Re: Stubborn Brake Light Problem
Why not test the bulb on its own if the problem follows the bulb.
The bulbs for the rear lights are not halogen they are tungsten bulbs.
Old Dec 28, 2019 | 11:46 AM
Enmanuel09's Avatar
I forgot to mention that both bulbs light up when just turning on the tail lamp but not when braking. Regardless, I think I’m going to do that and maybe buy the tungsten thanks onehundred80.
Old Dec 28, 2019 | 02:39 PM
A full description of the problem certainly helps and saves time.
There should be two filaments in each bulb, is the brake light filament broken in one.
Are they both the correct bulb?
Are there two contacts on each of the bulbs? Maybe one bulb has only one contact.
Old Dec 29, 2019 | 01:33 PM
Enmanuel09's Avatar
I checked the bulb and indeed it was missing a filament. Replaced it with a new one and works just fine! Don't know how could I miss that Thanks onehundred80
wootto
U.K.
Aug 16, 2020 07:55 PM
AlexParra
Nov 4, 2015 08:53 AM
AlexParra
Dec 9, 2013 02:10 AM
BlazingSaddle
Jun 29, 2013 04:58 PM
blackoutken
Jan 25, 2012 11:21 AM
