2005 engine stops in middle of road
Old Feb 5, 2020 | 01:14 PM
hvandriel's Avatar
Default 2005 engine stops in middle of road
Hello, We have a 2005 coupe and recently have experienced the engine stopping while driving with no warning and cannot get it started unless the engine cools down. Jumping does not do anything. Becoming unreliable and unsafe to drive at any speed. Local Chrysler dealership has no idea--been there several times. Does anyone have any ideas? Thanks so much
Old Feb 5, 2020 | 02:07 PM
Default Re: 2005 engine stops in middle of road
Sounds like your CPS. Do a search on this site for symptoms and replacement info. Be sure to use Bosch parts as others do not always work.
Old Feb 5, 2020 | 02:54 PM
monaderio's Avatar
Change the battery in the key fob first
Old Feb 5, 2020 | 03:03 PM
cowancom3's Avatar
Here is a link to the Bosch cps
https://www.autohausaz.com/pn/0232103037
Old Feb 5, 2020 | 04:34 PM
The battery in the FOB is for the transmitter that locks and unlocks the doors, and only that.
The RFID chip in the key is what enables engine start, but once the car is running, it's job is over.
This is a classic "my Crank sensor won't let the car run until it cools off...."
Go get yourself a BOSCH crank sensor at GermanAutoSupply.com or FCPeuro.com.
YOu can buy one at Advance or where ever, but often their parts are not quite to spec and you end up fighting a ghost.
Just go online and google "Mercedes 2003 SLK320 Crank Position Sensor" and buy the BOSCH part, not the cheap fake parts.
Old Feb 5, 2020 | 04:35 PM
THat is the CAM sensor (Which can be the problem but most often, it's the Crank sensor).
Old Feb 5, 2020 | 04:48 PM
monaderio's Avatar
Well, start the engine, remove the battery and make a trip. I have had a few stops of engine while driving the car from Connecticut to Florida. The reason is a key fob dead battery.. After replacing the battery in NJ the problem had gone. Still have no any issues.
Old Feb 5, 2020 | 04:51 PM
monaderio's Avatar
As I said before change the key fob battery first , then replace cam and crank sensors
Old Feb 5, 2020 | 05:18 PM
tighed1's Avatar
As mentioned, most likely the CPS. Check for fault codes. CPS will throw a code. Replace with a BOSCH CPS ONLY.
If no code, could be the relay control module. Turn the key to the ON position and wait 30 seconds.
If the radiator fan spins up REALLY fast, RCM is the problem. I can fix it if bad.
Old Feb 5, 2020 | 11:41 PM
The fob batteries have absolutely nothing to do with starting the car. Those batteries only enable the doors to be opened remotely.
Old Feb 6, 2020 | 03:48 PM
Non sequitur, nothing to do with his problem!
Again, non sequitur, nothing to do with his problem! Your post is confusing and not helping.
Old Feb 6, 2020 | 08:53 PM
lotsofspareparts's Avatar
Change the Crank Position Sensor and the Cam Position Sensor together.
Mine hadn't even gone out yet and they both got replaced. PREventative maintenance.
I think I paid $60 for both of them, both Bosch on Amazon.
To reiterate as others have said, key fob batteries don't have anything to do with the car stalling or not starting.
Jared
Old Feb 6, 2020 | 09:15 PM
monaderio's Avatar
So what the issue did I have? The engine got off while I was driving on highway. Couldn't start the car again and annoying sound came up when I was trying to start the engine. Then I disconnected the battery for about 5 min or so put the battery terminal back and then everything was fine. It happened to me 3 times until the battery in the key fob has been changed. After replacing the battery I have no any issues at all.
That's why I was offering to replace the key fob battery.
Old Feb 6, 2020 | 09:25 PM
That is one hell of a coincidence. I drove one of my XF's around for a while with NO batteries in either one of my fobs.
There is literally a ZERO chance that your running issues would be caused by dead batteries in your key fob.
Jared
Old Feb 6, 2020 | 09:35 PM
monaderio's Avatar
Forgot to mention that the batteries in the alarm module were dead as well. Is there any connection with my issue?
Old Feb 6, 2020 | 09:38 PM
No, dead batteries in the alarm module don't affect anything but the alarm not sounding.
Leaking batteries in the alarm module will cause the alarm to go off randomly though.
I really do think your situation was purely coincidental.
Jared
Old Feb 6, 2020 | 09:42 PM
monaderio's Avatar
Magic sometimes happens LOL
Old Feb 6, 2020 | 10:25 PM
If my kept stopping in the middle of the roadI would drive more to the side of the road until I had changed the CPS.
Old Feb 26, 2020 | 03:01 PM
CarolBanks's Avatar
Okay, I read all the responses to engine/car stops and can't crank back up. Just recently having the same problem. But the issue started in May 2015 when the mechanic removed and replaced the rear right wheel speed sensor and secondary air injector. Codes P0410 - Secondary Air Injection System, P0500 - Speed wheel sensor. From 2015 up to current, I've changed I believe a total of 3 speed wheel sensors. Recent diagnosis done February 2020 says Codes P0410 - SAIS, P0335 - Crankshift Position Sensor A Circuit, P0151 - 02 Circuit Low Voltage (Bank 2, Sensor 1). I have a 2006 Crossfire 6 speed, base model, Red. My ex hubby purchased off the showroom floor. Unique car indeed. He gave the Crossfire to my Son, Juan and my Son sold it. DoggoneIt! I went and purchased it back from the company that bought it without revealing who I was nor let my son know about it. I asked the dealer to deliver to my home and park in my driveway because I was leaving for Massachusetts. Came back home, called my Son to come to the house. I asked him, Is this our Family Car. He said, Yes, Mom. I asked him to check it over thoroughly. Well they really screwed up the family Crossfire and put the wrong oil in it, messed up the beautiful shine, took the original car mats and the freakin Good Tires on the back. It took a while to fix all of this. So with that said, I am going to do all 3 recommendations. Mainly because the Crossfire is 14 years old. She due for replacing belts and all kinds of parts. Which is what I've been doing. Even put a new wing on her in Black to match the black trim. Thank you helping me solve the issue. Appreciate it. Pie Banks-- Grandma's Ride & Baby's Toy!
Old Feb 26, 2020 | 03:48 PM
Thanks for letting us know if the problem was solved or not.😏
Maybe we just ignore your pleas for help next time.
franklindm
Mar 14, 2020 12:23 PM
mozzer
Apr 29, 2018 03:26 PM
Tar Heel David
Apr 16, 2018 10:45 PM
Grant JC
Nov 12, 2011 10:40 AM
samo59
Dec 19, 2009 02:17 PM
