Help! Key Fob randomly stopped working and car won't start
Old Jul 29, 2020 | 09:03 PM
Heytherebeaux's Avatar
Default Help! Key Fob randomly stopped working and car won't start
Hi there - 2005 soft top coupe owner here
Just had the relay replaced about 2 weeks ago, a new battery installed in January and now Shaka (my cars name) is giving me a hard time again.
Last time this happened to me, I had to replace the key. Not sure if thats the case again.
And yes, I 1) changed the batteries 2) made sure they were in correctly 3)unplugged the battery for 60+ secs and then attempted to unlock and still no dice.
Any other suggestions?
Thanks in advance
Old Jul 29, 2020 | 10:50 PM
Default Re: Help! Key Fob randomly stopped working and car won't start
"Car won't start" - that tells us nothing.
Does the starter engage? (yes or no)
What sounds do you hear? (If the starter does not engage, what do you hear when you turn to start?)
If you turn the key to start, then let it go back to on - does the engine cooling fan slowly ramp up to high speed in about 30 seconds? (If it does, we know what is wrong - if not, we have more questions...)
Old Jul 30, 2020 | 12:29 PM
KDW4Him's Avatar
A Crossfire key FOB has 3 functions, first is a metal key to put into the ignition/door to turn the tumblers. Second is to prove to the car's alarming the correct FOB is turning the ignition with the metal part. Third is to remotely lock/unlock the car. This last function is the only function the batteries in the FOB are needed for. The first two is hardware. Did you perform the FOB re-sync procedure after the battery replacement?
Old Jul 30, 2020 | 06:08 PM
Thanks everyone for your input. After giving Shaka a rest overnight, I had to manually open the door this morning and the alarm lights miraculously did not flash as they did yesterday. And she started right up with no issue. And after turning her off, the key fob also started to control the locks again.
AlexParra
Jul 13, 2020 09:06 PM
John&Terry
16
Feb 8, 2019 11:55 PM
Firefly2018
Jul 13, 2018 12:09 PM
nickwe21
Jun 10, 2017 05:31 PM
manisusmc
Apr 14, 2010 05:23 PM
