19lb injectors without tune?
Old Sep 19, 2020 | 09:00 PM
Rsoe's Avatar
Default 19lb injectors without tune?
I have a question regarding the 19lb injectors. If I reset the car by disconnecting the battery, will the cars computer adjust to the 19lb injectors or will it required a tune. The ecu must know what size the injectors are but it will not adjust according to the data it is receiving?
Old Sep 19, 2020 | 10:15 PM
Default Re: 19lb injectors without tune?
Moved to appropriate forum.
Old Sep 20, 2020 | 08:37 AM
buford05's Avatar
How about telling us where you moved it to. I've opened all the heading ( engine, tsb,modifications etc and I don't see it)
Old Sep 20, 2020 | 10:48 AM
What do you mean? You are HERE, you POSTED in the moved thread.
Old Sep 20, 2020 | 10:54 AM
"Here" is :
Old Sep 20, 2020 | 03:14 PM
RSOE, do you have an SRT-6 or an N/A? Your profile picture is of an N/A if that is what you own. Just curious...
Old Sep 20, 2020 | 05:16 PM
Rsoe's Avatar
Yes N/A. I added the upgraded throttle body and definned the elbow. Added the 3” housing. I know to take advantage of these upgrades a tune is what is best. But I am wondering if the tune is a necessity in the meantime. The ecu should learn the injectors but then again it will think it is stock injectors installed and possibly throw a code.
Old Sep 21, 2020 | 08:36 AM
buford05's Avatar
Sorry for the misunderstanding.I thought that you moved it from there to someplace else.
Old Sep 21, 2020 | 03:15 PM
AFAIN the injectors on the N/A is capable (OEM ones) and are fine with the tune for the N/A.. Did you 'up' your injectors? The tune for the larger TB and descreen MAF/debaffle elbow work is one of the upgrades but injectors? Maybe someone else can chime in here but my tune with the stock injectors and the descreening MAF & debaffle the elbow works great. I don't recall an injector upgrade for the N/A. Mine never popped a code, just had extra 'git-up-n-go'!
Dec 30, 2015 08:52 AM
rmcdaniel12
May 18, 2015 08:55 PM
black05
Mar 24, 2009 07:55 PM
HyprLtH20
May 29, 2008 01:08 PM
tylerxfire
17
Apr 23, 2008 08:58 AM
