Changed conductor plate now no start
Old May 22, 2021 | 03:36 AM
Tminard's Avatar
Default Changed conductor plate now no start
I just changed the conductor plate
Now car won't start. All electrical components work just wont do anything when u turn the key
Old May 22, 2021 | 11:10 AM
Default Re: Changed conductor plate now no start
First try the "Mystery No Start" solder job on the RCM
Old May 22, 2021 | 11:11 PM
Tminard's Avatar
Checked RCM , everything is fine.
Disconnected battery cables and touched them together for 20 sec. Still no start.
Old May 23, 2021 | 02:48 PM
zip439's Avatar
You need to clear all the codes that have been set; That scan must get into the transmission/Mercedes codes, a common generic OBD II scanner will not go deep enough. Clear all your codes then try to start the car; still no go re check any set codes.
Old May 23, 2021 | 04:29 PM
We can assume you did not harm and did put the electrical plug back in?
Old May 23, 2021 | 10:00 PM
Tminard's Avatar
Yes I plugged it in without damaging it
Old May 23, 2021 | 10:18 PM
For the MILLIONTH time, do this:
Get in car, close door (or don't, I don't care.)
Turn key to start - does it engage starter?
If not, relax key to "ON".
Wait 30 seconds.
Does engine cooling fan warp up to high speed?
If so, it IS the RCM. PERIOD.
If not, we have some more homework to do..............
Old May 24, 2021 | 10:08 AM
Tminard's Avatar
I went out to do what you said and the car started this time. I shut it off and on several times, keeps starting now. For most people they would think great problem solved but for me it just worries me.
So now what do I do? I'm assuming it's the RCM but not sure.
Old May 24, 2021 | 10:26 AM
Tminard's Avatar
I have one more question.
The two electrical plugs under the tyranny, I didnt realize they were the same or I would have marked them . How do I know which one goes where?
Old May 24, 2021 | 01:28 PM
Sure sounds like RCM to me. Having a spare is a good idea, I think I'd order a new one and put it in the trunk!
Then just wait..............
roychez
Mar 19, 2021 02:50 PM
Mdcrossfire
Dec 13, 2018 06:35 PM
ericfragola
Sep 25, 2013 06:13 PM
Skippy911
Jul 2, 2013 01:47 PM
jason60050
Jan 10, 2006 07:34 PM
