Ayone knows what this is? (Under the truunk floor panel)
Old Jun 24, 2021 | 07:25 AM
Predator's Avatar
Default Ayone knows what this is? (Under the truunk floor panel)
Hello. I'm trying to find out what this part inside the trunk, under the floor panel is. I observed it started to get swollen.
Maybe someone can point me in the right direction, thank you!
Old Jun 24, 2021 | 08:17 AM
zip439's Avatar
Default Re: Ayone knows what this is? (Under the truunk floor panel)
You should have two pieces of styrofoam that fits to the right and to the left of that piece. The pieces that are not show will hold tools in the right piece and the one to the left holds the air pump and tire fix. That piece in the center of the car is insulation for the exhaust pipes which are directly under the car.
Old Jun 24, 2021 | 08:43 AM
Predator's Avatar
Oh I see now, so maybe it got swollen because of the heat. I thought it has something to do with the fuel tank.
There's nothing to worry about then, thank you so much for your help I really appreciate it.
Old Jun 26, 2021 | 09:07 PM
cammons's Avatar
it is insulation for the muffler so that the carpet does not get hot.
Old Jun 26, 2021 | 09:29 PM
Side note; The pump is part of your security system and will go haywire if it gets wet.
Under that pump is a small black rubber plug. many of us have removed it to allow any water that may end up in that well to drain.
Also, since you don't have the Styrofoam box on the pump. you might consider putting it is a big zip lock bag.
I have replaced several of these pumps because of water. Since bagging them and pulling that plug no issues.
Old Jun 27, 2021 | 05:48 AM
Predator's Avatar
Thank you everyone!
That's not my picture, it's the only thing I could find to show you what I'm talking about. I didn't want to take everything apart.
bc75
Dec 27, 2019 04:43 PM
gcongle
Aug 15, 2017 08:55 PM
nickwe21
Dec 11, 2014 10:55 AM
smokey847
Feb 12, 2011 10:52 PM
Bulldogger
Nov 21, 2007 07:16 PM
