Car locks with fob, hatch does not
Old Jun 26, 2021 | 11:46 PM
Tomwas's Avatar
Default Car locks with fob, hatch does not
I lock the car with the fob and all seems good. Tried to open the hatch and it opens right up, not locked/secured... Four way flashers come on when the hatch opens, then I unlock and lock with the fob to turn off the flashers as I'm sure an alarm wil! Sound.. Okay, what is up with this situarion... Can't really secure/ lock my car...!!!😮
Old Jun 27, 2021 | 06:22 AM
Doc78's Avatar
Default Re: Car locks with fob, hatch does not
Are you pressing the lock button on the fob twice?
https://www.crossfireforum.org/forum...tml#post588191
you can program the fobs to different functions.
I put the link above
Hope this helps
Old Jun 27, 2021 | 07:12 AM
Tomwas's Avatar
Thanks
Old Jun 27, 2021 | 12:47 PM
quite possible the yellow plastic vacuum/pressure line is fractured at the point where the trunk hinges at the roof.
Old Jun 27, 2021 | 02:52 PM
As the hatch lock is not locked maybe the alarm will not sound, if you press the button does the alarm sound?
As said earlier the yellow air hose is probably torn in the corrugated hose that runs between the hatch and body.Some have spliced over the leak with a larger hose. If you want to replace the hose use a 6mm urethane hose, the yellow hose is not known for lasting. It is a major job time wise to replace the hose from pump to hatch lock.
The yellow hose passes through the passenger side corrugated hose at the top of the hatch. It is incorporated in the wire harness loom making it almost impossible to wholly remove, just remove what you can.
tpellegr
May 16, 2017 11:45 AM
Almos
Apr 1, 2017 03:31 PM
chturner
Apr 18, 2015 11:11 PM
dsdesigns
Feb 6, 2014 08:05 AM
XF504
Apr 8, 2010 07:12 PM
