Help - Looking for Parts 2004 Chrysler Crossfire
Old Nov 17, 2021 | 12:12 AM
rubyl0926's Avatar
Default Help - Looking for Parts 2004 Chrysler Crossfire
I just recently bought a 2004 Chrysler Crossfire - it needs some TLC. Can anyone help me locate a few parts?
- Fuel gauge indicator not working. I believe it's a sensor? If yes, what is it called and where can I purchase?
- Steering column ignition bezel. I believe this is what it's called. It's the ring around the area where you insert the key. It is loose and I believe it is broken. Can someone please confirm the part name and where I can find a replacement?
ANY help would be appreciated!
Old Nov 17, 2021 | 09:52 AM
Default Re: Help - Looking for Parts 2004 Chrysler Crossfire
your fuel gage COULD be the rcm (Mercedes k40) replace that first as for the ring it has two wires behind it one may be disconnected it is programed to the key fob ,,call Rob at Needswings,com he has the fix.
Old Nov 17, 2021 | 11:28 PM
rubyl0926's Avatar
Thank you!!! I will give that a try and update post with results!
Old Nov 17, 2021 | 11:49 PM
How does the RCM have any affect on the fuel gauge? The fuel level sensor is in the fuel tank, I guess a fuse is in the circuit as well.
He says the ring is loose and says nothing about the wires, presumably the car starts or he would have said so.
He would be better of looking at the Service Manual, for which a PDF can be found in the Documentation Collection.
It can be found in the TSBs and How To section. He can download and save it for future reference.
Old Nov 18, 2021 | 08:59 AM
A fuel PUMP that wont run or does not run right is usually the RCM, a fuel GAUGE that wont' work right is almost always the sending unit in the tank. (Altho I've had issues with the connector at the top of the tank in Roadsters, as water can get in there, not so much with Coupes, and being an 04, the person here is talking about a coupe.)
Old Nov 18, 2021 | 09:02 AM
It doesn't. The fuel gauge is driven off the ignition feed from the switch itself, not via the RCM.
Old Nov 18, 2021 | 09:30 AM
That was my point, too many answers here are not based on fact and the suggested solutions lead to the spending of hard earned wages on something that does not solve the problem. It's pretty painless to spend someone else’s money.
Likewise the question on the halo ring, it is loose so why buy another before the cause is researched.
Many answers on this forum are really no more than adverts for the services of some members. Is that idleness or the search for brownie points? I do not think I have ever suggested people spend money on the hope that it will solve the problem, the dealers do that and it gets expensive.
One members consistent answer to many questions was to do a throttle reset, I have only done one throttle reset and that was some 15 years ago just to see what the result was, not much if I recall.
Old Apr 22, 2022 | 10:54 AM
jboek's Avatar
i have lots of spare parts plus the working fuel gauge
my name is john text me at 226 934 4808
bluey42
Australia
May 29, 2022 04:54 AM
ikshi
Jul 15, 2020 08:57 PM
frozenith
Oct 1, 2017 05:53 PM
demd
Mar 11, 2016 11:49 AM
Beagles
Canada
Aug 10, 2012 09:34 PM
