Chunky, difficult shifting int 1and R?
Old Dec 2, 2021 | 09:14 PM
No704's Avatar
Default Chunky, difficult shifting int 1and R?
110k miles, roadster, 6 speed manual. Shift link bushings wore out?? Or?? Where or what to replace?
Old Dec 4, 2021 | 07:22 AM
Default Re: Chunky, difficult shifting int 1and R?
Are you SURE the clutch is fully disengaging?
Have you verified fluid level?
I don't get how a six speed gets into this much trouble at 100,000 miles. My Graphite had 44,000 on it when I got it, and it shifted kinda clunky. Around 60,000 I replaced the fluid with 5W20 Mobile 1 which helped a bit; by the time I got to 100,000 it' actually shifted better - I came to the conclusion that what these six speeds needed, was MILES and new fluid.
My SE has 62,000 and it got fluid around 50,000 and does not shift badly at all.
How you could have worn anything out is beyond me, but I guess it's possible.
Old Dec 4, 2021 | 03:55 PM
No704's Avatar
I’m not SURE. Just tried it with the engine off, smooth. I believe you are on to something with the clutch not totally disengaging. Will check fluid.
Old Dec 6, 2021 | 09:58 AM
dcskmail's Avatar
You might want to flush and replace your brake/clutch fluid , bleed the brakes and clutch slave . The hydraulic system and master cylinder share the same fluid with the clutch and brakes
Old Dec 10, 2021 | 05:04 PM
No704's Avatar
Checked the fluid, it’s over full. It’s not always difficult to shift? Seems to be a common complaint. Guess I’ll just live with it.
phil alvirez
Apr 27, 2021 03:25 PM
ardenian
Jun 14, 2019 11:18 AM
Padgett
Sep 2, 2014 09:39 PM
judson
Aug 19, 2004 03:30 PM
mea
Dec 28, 2003 12:11 PM
