Height of wings
Old Mar 13, 2022 | 09:26 AM
oli's Avatar
oli
Default Height of wings
Hello , I would like to know if you have same value. I thought what my front is to low. And I don't know why.
Old Mar 13, 2022 | 10:29 AM
Default Re: Height of wings
How many miles, front or rear, probably a bad shock?
Old Mar 13, 2022 | 10:31 AM
oli's Avatar
oli
Front is lower than the rear. Shocks look Good .
Old Mar 13, 2022 | 10:40 AM
oli's Avatar
oli
In inch it makes 1,5 inch between front and rear . How about your car ? My car is stock , is there a technical way to adjust height?
regards
Old Mar 13, 2022 | 11:32 AM
oli, did you buy it new? Was there any suspension work done by you if you purchased new? Are the tires OEM SIZE? IF someone else replies these values are not within OEM values I would suggest you check out if suspension work was done OR something failed (especially if BOTH sides are about the same as you posted, since you never mentioned this). When you check both sides, make sure the car is on a LEVEL surface! Good luck!
Old Mar 18, 2022 | 04:44 AM
oli's Avatar
oli
hello , thanks for your feedback .
my car is stock , and had only 80.000 km. Wheels and tyres are standard size .After changing the upper arm of suspension ( i change it because it has a slack ) , now when i turn fully the steering wheel the wheels touch the body.
correctly measure of height from tyres to fender, makes that the front is lower that the rear about 4 cm so it makes 1,5 inch .
i suppose that the car has made a jump and front arm has been damage .
i will check the front and rear height , and shock absorber condition , lenght of spring and if some part are bend.
can some one makes a measure from the ground to the jack point at front and rear on a standard car with original suspension?
regards
Old Mar 21, 2022 | 11:55 AM
oli's Avatar
oli
finally i unmount the spring and i discover that half a round was cut .
regards
Old Mar 21, 2022 | 07:55 PM
regards
Makes perfect sense. Thanks for reporting back. IF it is concerning enough to you to fix, a few members are selling their replaced OEM springs. Check out the for sale forum, and also someone might reply here if they have a set for sale/trade (if interested). Good luck!
Chris L.
Dec 19, 2024 05:37 PM
Big Daddy
Canada
Jun 19, 2017 04:19 PM
Crossfire725
Nov 19, 2009 06:48 AM
James1549
Midwest Forum
Aug 17, 2008 09:20 PM
huudoo
May 20, 2008 05:53 PM
