3.90differentiai gears for any crossfiresrt6 or na.
Old Mar 27, 2022 | 06:57 PM
Tomcross's Avatar
Default 3.90differential gears for any crossfire srt6 or na.
amx1397 and i have done it in my srt6 and it runs great ,we can supply a turnkey setup that bolts into any crossfire srt or na with out any modification to the car . it can be returned to stock by putting back original parts there is a limited supply of these new differentials after that we have to use used ones.we also supply a modified tcm so no limp mode ,we are working on a wavetrack for this setup i have over 1000 miles with no problems .contact amx1397 if your interested it makes a big difference in acceleration. there also other ratios available setup 3.64 and 2.87.
Old Mar 27, 2022 | 10:08 PM
Default Re: 3.90differentiai gears for any crossfiresrt6 or na.
This was the first car we installed the 3.90 ratio rear ,now we have another and this one is a modified srt6 ,,will be going to a drag strip soon as the track opens in Wisconsin and my car will have a 3.90 in it soon, and will also run at a track.
this is a bolt in mod, you get the differential, open gears),TCU and the bolts that make the change,, the srt6 requires one extra part ( yoke part)
the cost for the limited is $1599.00 for the srt 6, $1799.00 ((price as of April 2022))
Old May 10, 2024 | 06:25 PM
WD40's Avatar
So no one else need look it up, the factory SRT6 differential gear is 3.07:1. All other Xfires are 3.27:1. Manual or automatic makes no difference.
Old May 11, 2024 | 10:10 AM
Yes but , we have now different ratio 's to give the crossfire the boost or gain mileage we have a 2,87, 3.07, 3.27 3.66 and 3.90. I am offering the 3.90 at a reduced amount
of $995.00 for the TCU and the diff with 3.90 gears,, this can be swapped in about 2 hours ,,yes it is a bolt in. this set up in a limited will make it 1/4 second(on paper) slower than a srt6 where now it is about 1 full second slower than a srt6,,, I see post how to make a limited faster well this is it. My V8 with a 3.45 runs 10.55 @ 132,, with the stock 307 it ran 11.0 @ 121. and all your parts you remove ( the 3.27 diff and tcu(for auto) you can put back when you sell. For std shift crossfire I can do $800.00
Blacksunshine
29
May 3, 2019 06:49 PM
ardenian
Nov 1, 2016 06:17 AM
crookedview
Nov 19, 2009 08:06 PM
enjoinick
21
Jul 31, 2008 07:30 AM
nascarhq
May 19, 2008 09:39 AM
