Used parts - keep or pitch?
Old May 14, 2022 | 03:49 PM
g3air's Avatar
Question Used parts - keep or pitch?
I had a good bit of maintenance done recently on our 2005 roadster (40K+ miles) and requested the used parts be returned. The "old" belt looks like new (no signs of any wear) and the spark plugs also appear unworn (a bit dirty, but in appearance, unworn). Should I pitch or ....?
Old May 14, 2022 | 03:58 PM
bluecoupe's Avatar
Default Re: Used parts - keep or pitch?
I'd keep the belt as a spare in case of a roadside emergency, let's hope you don't have to use it. I think you have changed the plugs a good bit early. I changed mine at 100K miles (160k kms) and they still looked good, no problems with them. I also changed my plug wires when I did the plugs.
Old May 14, 2022 | 04:28 PM
g3air's Avatar
You are likely correct about my being too early, but it's a done deal. Think I'll hang on to both belt and plugs (too good looking to pitch). And yes, I had the plug wires replaced as well (but I have already pitched them).
Old May 14, 2022 | 11:50 PM
why start a new thread? You could have just edited the post you did six minutes before. To many posts on the same basic subject can get confusing, especially when they are minutes apart. Is your name Phil?
Old May 15, 2022 | 08:48 AM
stryfox's Avatar
Keep the belt in the hatch under the mat incase for a roadside problem.
the plugs are good to change early. When left in for a long time they can be quite difficult to remove. It’s actually not a bad idea at this point for low mileage cars to just remove them put some antisieze on them and put them back in.
grandpamike
Mar 29, 2017 06:28 AM
MRBOSS
Nov 20, 2012 04:32 PM
everrion
Oct 10, 2008 04:17 AM
ejavis1
Aug 15, 2008 05:52 AM
roms33
Nov 18, 2004 12:02 AM
