Water in Passenger Floor (SRT)
Old Jun 15, 2022 | 01:27 PM
rickshapiro's Avatar
Default Water in Passenger Floor (SRT)
I have water that has pooled up on the passenger floor. The air conditioner is not working as no cool air is coming through and the fan does not appear to be on. I have a service appointment in 7 days and as much as I wet vac the water and leave the car outside with the top down, the water seems endless. The water is a bit brackish but it is indeed water. I am not looking to fix the issue on my own but am wondering the best way to drain the water so it is not draining into the car. I just need to buy some time before my service.I am not too handy.
Regards,
Rick
Old Jun 15, 2022 | 02:30 PM
Ronman's Avatar
Default Re: Water in Passenger Floor (SRT)
Regards,
Rick
You need to remove the cowl and there are 3 drains that need to be unclogged, the middle one is usually ok but check them all.
Old Jun 15, 2022 | 03:32 PM
Regards,
Rick
Water usually gets in when the passenger side drain under the cowl gets plugged with debris, this is a most often caused when the car is parked under trees with small leaves, the leves act as a filter and start to trap smaller particles. It is wise to check this drain often, it can be seen through the rubber comb cover where the hinge goes There is a similar drain on the drivers side and two drains in the centre of the cowl area. These other drains do not seem to cause too much trouble but should be checked so that they do in fact do their intended task.
srjoecow
Nov 25, 2021 11:58 AM
rekcah
Feb 7, 2019 06:59 AM
Loumarino800
Mar 30, 2013 01:30 AM
mr-lama
Detail Shop
Nov 9, 2010 09:50 AM
Ringmaster
Aug 10, 2009 05:50 AM
