SRT6 SC/IC Upgrade Parts & Prices
Old Aug 24, 2005 | 07:02 AM
HDDP's Avatar
Default SRT6 SC/IC Upgrade Parts & Prices
Here's the best list I could put together to upgrade our standard Crossfire to the specs of the SRT6. I'm still not clear if the ECU needs to be changed as well. I'll find that out ASAP. The braking system is also included, as well as the different cam shaft gear. Not sure if the cam shaft is different, another thing to check, but would explain the lower compression ratio. The prices are a bit confusing, the first price is the dealer price, the second is an online vendor I found. The total is at the bottom... It looks like a hell of alot better price than the $12,000 I was quoted by Kleeman, but this looks like it would be a hella do-it-yourself project !!! The parts schematics are in my gallery... I haven't seen anyone on the forum who can really answer the question if this modification is actually feasible without a nightmare of problems, so if any of the factory people would like to chime-in it would be appreciated.
Cooling, Intercooler, Intercooler, Intercooler - W/supercharger 1 $210.00 $156.24 $0.00 $156.24
Cooling, Intercooler, Intercooler, Insulator, Insulator - W/supercharger 1 $2.70 $1.98 $0.00 $1.98
Cooling, Intercooler, Bracket, Bracket - W/supercharger 1 $28.50 $21.08 $0.00 $21.08
Cooling, Intercooler, Connector hose, Connector hose - W/supercharger 1 $3.05 $2.26 $0.00 $2.26
Cooling, Intercooler, Outer hose, Insulator, Insulator - W/supercharger 1 $7.50 $5.58 $0.00 $5.58
Cooling, Intercooler, Air baffle, Air baffle - W/supercharger 1 $67.00 $49.60 $0.00 $49.60
Cooling, Intercooler, Intercooler, Bracket, Bracket Right - W/supercharger 1 $8.00 $5.95 $0.00 $5.95
Cooling, Intercooler, Pump, Pump - W/supercharger 1 $308.00 $228.16 $0.00 $228.16
Cooling, Intercooler, Clamp, Clamp - W/supercharger 1 $6.50 $4.84 $0.00 $4.84
Cooling, Intercooler, Outer hose, Clamp, Upper - W/supercharger 1 $2.00 $1.49 $0.00 $1.49
Cooling, Intercooler, Intercooler, Bracket, Bracket Left - W/supercharger 1 $8.00 $5.95 $0.00 $5.95
Cooling, Intercooler, Pump, Buffer, Buffer - W/supercharger 1 $4.40 $3.22 $0.00 $3.22
Cooling, Intercooler, Radiator hose, Radiator hose - W/supercharger 1 $13.00 $9.61 $0.00 $9.61
Cooling, Intercooler, Outer hose, Outer hose - W/supercharger 1 $40.00 $29.76 $0.00 $29.76
Cooling, Intercooler, Outer hose, Clamp, Lower - W/supercharger 1 $1.20 $0.87 $0.00 $0.87
Cooling, Belts and pulleys, Serpentine belt, W/supercharger, W/supercharger 1 $55.00 $40.92 $0.00 $40.92
Engine, Supercharger and components, Air duct, Air duct Right - W/supercharger 1 $227.19 $169.04 $0.00 $169.04
Engine, Supercharger and components, Air duct, Air duct Left - W/supercharger 1 $227.19 $169.04 $0.00 $169.04
Engine, Supercharger and components, Supercharger, Supercharger - W/supercharger 1 $2,140.00 $1,587.20 $0.00 $1,587.20
Engine, Supercharger and components, Tensioner, Tensioner - W/supercharger 1 $52.00 $38.44 $0.00 $38.44
Engine, Engine parts, Camshaft gear, Camshaft gear - W/supercharger 1 $61.00 $45.26 $0.00 $45.26
Engine, Engine parts, Crnkshft seal, Crnkshft seal - W/supercharger 2 $8.28 $6.98 $0.00 $13.96
Front suspension, Brake components, Caliper, Caliper Right - W/supercharger 1 $474.00 $352.16 $0.00 $352.16
Front suspension, Brake components, Caliper, Caliper Left - W/supercharger 1 $474.00 $352.16 $0.00 $352.16
Front suspension, Brake components, Rotor, Rotor Back - W/supercharger 2 $92.00 $68.20 $0.00 $136.40
Engine, Engine parts, Crnkshft damper, Bolt - W/supercharger 1 $3.20 $2.36 $0.00 $2.36
Exhaust system, Manifold, Exhaust manifold, Exhaust manifold Right - W/supercharger 1 $380.00 $282.72 $0.00 $282.72
Exhaust system, Manifold, Exhaust manifold, Exhaust manifold Left - W/supercharger 1 $340.00 $252.96 $0.00 $252.96
Exhaust system, Manifold, Exhaust manifold, Gasket, Gasket - W/supercharger 2 $2.20 $1.61 $0.00 $1.61
Total: $3,970.82
https://www.crossfireforum.org/galle...cat/500/page/1
Old Aug 24, 2005 | 10:19 AM
Dan Root's Avatar
Banned
Default Re: SRT6 SC/IC Upgrade Parts & Prices
You forgot the rear-end ratio is also different! That would be another $k at least. Times 2.5 for labor and warranty and profit = $10,000+ minimum by a Benz shop.
Old Aug 24, 2005 | 01:13 PM
HDDP's Avatar
No I didn't forget that the rear end is different. I have a 6 spd manual and have made arrangements to have a 3.85:1 pumpkin installed. Thanks for the addition for those who don't know. If you wanted to really get into it, you'll have to change the front sway bar as well. But I figured most people who are pursuing this type of upgrade will have a performance suspension...
Old Aug 24, 2005 | 06:53 PM
x'ed's Avatar
hey hddp, where did you get those prices from, they seem to look cheaper than the mopar prices with the supercharger being $1,585.
Old Aug 25, 2005 | 12:16 AM
cross1's Avatar
NOW!!! That's what I'm talking about...Kudos, now if we can get 1 "test car". One question, what's the difference in the rear-end Ratios between the two cars (SRT/Limited)?
Thanks,
Carl
Old Aug 25, 2005 | 01:05 AM
TheCrossfirekid's Avatar
are these from my mopar link? or a different page? also here is a link to a thread i started, it has a list of all the parts in the kleeman kit for the slk320 supercharger. so basically, i'm thinking these are the parts you need to make a "kit" for the crossfire and requirements.
https://www.crossfireforum.org/forum...ead.php?t=8492
stlas69
Sep 3, 2015 10:28 AM
leaddog2015
Jul 13, 2015 12:25 PM
2005 Ragtop
Jul 9, 2015 03:16 PM
GWAPA
Jul 8, 2015 07:25 PM
James1549
Jul 6, 2015 10:36 PM
