'05 Xfire Limited: ECU / RCM box cooling
Old Mar 18, 2023 | 11:37 AM
Romad's Avatar
Default '05 Xfire Limited: ECU / RCM box cooling
Went for a morning drive for about 40 minutes. Parked car for about 10 minutes and then had a "no start" situation where I had dash lights but no starter crank. My '05 Xfire has been experiencing intermittent starting problems and was wondering if anyone thinks a too warm ECU/RCM could be part of my problem. Stuck my finger in that mysterious hole in the front bottom of the box and the fan bit me! It does push out air but how much is adequate for cooling the ECU. The air coming out seems a little warm and I do realize the air comes from the cabin. I do have a new cabin filter installed. Should the fan "pull" air from the cabin into the black box via the fan hole in the front of the box? What is the circulation path "in and out" of the black box? With the black box's cover installed seems it might not circulate. Has new cam and crank sensors.
Old Mar 18, 2023 | 12:05 PM
Default Re: '05 Xfire Limited: ECU / RCM box cooling
Have you replaced the crank position sensor with BOSCH brand? They are known to fail when hot.
Old Mar 18, 2023 | 12:10 PM
Romad's Avatar
Installed aftermarket ones. My new Bosch sensors might arrive today.
Old Mar 18, 2023 | 12:14 PM
Romad's Avatar
Aftermarket sensors. New Bosch sensors should arrive today.
Old Mar 18, 2023 | 01:27 PM
You accuse people of not reading - try READING.
His starter did not engage, the Crank sensor is not part of this.
Old Mar 18, 2023 | 01:47 PM
Originally Posted by Romad
Went for a morning drive for about 40 minutes. Parked car for about 10 minutes and then had a "no start" situation where I had dash lights but no starter crank. My '05 Xfire has been experiencing intermittent starting problems and was wondering if anyone thinks a too warm ECU/RCM could be part of my problem. Stuck my finger in that mysterious hole in the front bottom of the box and the fan bit me! It does push out air but how much is adequate for cooling the ECU. The air coming out seems a little warm and I do realize the air comes from the cabin. I do have a new cabin filter installed. 1) Should the fan "pull" air from the cabin into the black box via the fan hole in the front of the box? 2) What is the circulation path "in and out" of the black box? With the black box's cover installed seems it might not circulate. Has new cam and crank sensors.
Warming and cooling of the boards in the RCM does cause stress fractures to the solder connections. The ECU appears to have been designed and constructed such that it is immune to this.
Forget the cam and crank sensors, they play no part in starter engagement.
1) The fan draws cabin air from the cavity where the cabin filter is, after the cabin filter filters the air but before it passes thru the heater core or A/C evaporator.
2) The lid on the box is designed to resist air flow, but some still leaks past it, so there is flow.
The theory is two-fold.
A] The air brought in is cooler than what WOULD be in the box had they not force-vented it. The box is in an area that can get to 180F in the summer, sitting at a traffic light. By drawing air in that has passed the cabin filter, it is clean and of cabin temperature. Even with the top down in summer, the air will be no more than maybe 100F, and only then if you can stand to sit there and drive with the top down when it is 100F outside, this is way better than what the underhood temperature would be.
B] By causing there to be resistance to the blower's air flow, the air pressure in the box is SLIGHTLY higher than atmosphere, this keeps unfiltered, dusty underhood air out of the box, keeping it cleaner. Very important, as we all know how much dust can 'insulate' electronic chips and other components. This is why that box's insides looks pretty good in a car with 150,000 miles on it and dust and dirt all over the engine compartment.
The service manual explains the theory behind the blower in the ECU box, there is also mention of it in the Student Reference.
If the no crank appears related to a warm/hot car, I'd suspect the RCM. Otherwise, no cranks can be:
  • Interlock issue (clutch pedal switch in manuals, Shift lever assembly in autos)
  • Flaky battery voltage caused by flaky battery, corroded/bad battery cables, etc. (lower than about 10.4 at the ECU not the battery terminals or so will inhibit starter engagement in these cars and the SLKs)
  • Flaky pulse module (VERY rare)
  • Bad starter or starter solenoid (VERY rare and easy to diagnose with only a flat blade screwdriver, I can give you the procedure if you need it.)
  • A bad ECU (VERY VERY rare but I know of ONE case since 2009).
Anyone who tells you to change the cam or crank sensors because your starter is not engaging either did not READ your post or should not be giving technical advice. Please read the warning/instructional link in my sigline.
Old Mar 18, 2023 | 04:13 PM
Romad's Avatar
I did forget to mention that after sitting, for say about 30 minutes or so, it "usually" starts right up. Has a new RCM installed. Then "sometimes" in the morning it will give the classic crank, start, die immediately twice then nothing as if it is a SKREEM problem. Crazy symptoms! This problem has been discussed in a long post in my posted link below. The black box temp was a new thought so that is why I started a new post. Pizzaguy has been very helpfull with advice in the post. Still waiting on my better code reader to arrive in the mail. ( I could never get the $5 Android OBDII reader to work. It would pair with my phone but no worky! )
​​​​​​https://www.crossfireforum.org/forum...conumdrum.html
Pending a miracle discovery I still will be sending the SKREEM, ECU and FOB to MSS for the Key Delete mod. After that if I still have problems I'll be trading the car for a moped or electric bicycle! LoL
Old Mar 18, 2023 | 04:27 PM
Romad's Avatar
Thanks Pizzaguy that was quite a lengthy reply about the black box and it's operation.
Soooo does that mean there is no exhaust vent so air will be forced around and exited out of the black box? No back pressure created on the fan pushing air into the box?
Old Mar 18, 2023 | 05:51 PM
THe "exhaust vent" is the seal around the top of the box and the lid. The service manual talks about it but damn if I can find it.
THe student manual mentions it, but the service manual gives better detail.
Here is the Student manual mention of it:
Old Mar 18, 2023 | 05:55 PM
Pizzaguy, That wasn't directed at you. You know more about roadsters than anyone. I said that because a lot of folks kept posting about going in through the license light, as I have done myself, and he kept stating that the European version has plates welded in the way. I was just trying to keep down the traffic. No offence meant to anyone.
Old Mar 18, 2023 | 06:27 PM
Romad's Avatar
Are you sure you posted in the right discussion?
Old Mar 18, 2023 | 06:30 PM
Romad's Avatar
I took a 30 minute drive and upon returning home took the temp with a lazer tool. The front of the box was 117 and the ECU was 125. Doesn't seem to be that warm to cause a malfunction.
gstsaver
Oct 21, 2022 08:31 AM
WarrantCWO
Jun 1, 2022 12:27 AM
sama87
Apr 21, 2021 02:47 PM
GannyX
Jan 24, 2017 06:56 PM
hpmotors
Nov 5, 2012 08:34 AM
