cross fire 2005 falla
Old Aug 7, 2023 | 05:45 PM
davidperez12's Avatar
Default cross fire 2005 falla
tengo un crossfire 2005 no lo quiero vender en partes y ya programe dos llaves me dicen que el skreem funciona y tiene 4 llaves activas
Trata de encender 1 segundo y se apaga , despues de 3 intentos tengo que desconectar la bateria.
por cierto filtro de gasolina alguien sabe como se conecta ? creo que lo hicieron mal
nota si inyecto gasolina por el multiple de admision (aire) puedo mantenerlo encendido 30 segundos
lleva estacionado 3 años.
no lo quiero vender en partes es un gran coche.
Old Aug 8, 2023 | 01:49 AM
Default Re: cross fire 2005 falla
It could be a bad RCM (Relay Control Module). have you tried to see if you are getting any error codes?
In my opinion, if you decide to sell the car, it would be better to sell the entire car, not in parts.
Here is a diagram and a video. Good luck!
In the picture the fuel filter is number 17. The fuel pump is number 11.
Old Aug 8, 2023 | 03:03 PM
I have a 2005 crossfire I don't want to sell it in parts and I already programmed two keys they tell me that the skreem works and has 4 active keys
It tries to turn on for 1 second and it turns off, after 3 attempts I have to disconnect the battery.
By the way, does anyone know how to connect the gasoline filter? I think they did it wrong
Note if I inject gasoline through the intake manifold (air) I can keep it on for 30 seconds
It has been parked for 3 years.
I don't want to sell it for parts, it's a great car.
The fact that you must disconnect the battery to get three more bad cranks, tells me the SKREEM is the issue.
But if you can get it to run for 30 seconds with gasoline, I think M60 has it right: You have a fuel delivery issue. Measuring the fuel pressure at the rail with a fuel pressure test gauge is what I would do. THey are inexpensive test kits. You want about 60 PSI pressure. The pressure will be there when you turn key on, but if engine does not start, the pump will stop and pressure will fall quickly, this is normal.
For SKREEM problems, Josh Chase at https://themercedesswapshop.com/ would be who I would go to for repair. He is in California. He does not speak spanish but you can use google translate.
But again, if the engine tries to run with gasoline in the intake, I think the SKREEM is fine and you have fuel problems.
Old Aug 9, 2023 | 11:59 AM
Default
como comenté , ya programe dos llaves adjunto la foto
Hice una prueba quitando el chip de la llave hace lo mismo y se le pongo el chip mismo resultado .
si le desconecto el skreem igual lo puedo encender 30 segundos con gasolina por el múltiple de admisión , el skreem que bloquea ?
bomba? Chispa? Inyectores? A mi punto de vista bloquea los inyectores?
Ayer Le di 12 voltios a los inyectores para tratar de abrirlos pero se encendió la computadora
es un bonito carro y no me quiero rendir.
compraré manómetro para checar presión de combustible.
también probé el rcm y el fusible 11
el rcm probé los rele uno por uno los active de forma manual.
Old Oct 19, 2023 | 07:28 PM
cesarwalker1's Avatar
ASEGURATE DE QUE LA EL CONTROL DE LA LLAVE TENGA COLOCADA CORRECTAMETE LA PILA DEL CONTROL LA QUE VA EN LA LLAVE, te aseguro que tu problema es el skreem, el mío con el simple echo de que no tenga puesta correctamente la pila de la llave ya no enciende hace lo mismo que el tuyo,
cszkalak
Apr 3, 2011 10:15 AM
cszkalak
Feb 4, 2011 01:48 AM
jason60050
Jun 20, 2005 05:17 PM
HDDP
Racing
Nov 15, 2004 12:54 PM
