Lower valve cover leak
Old Sep 21, 2023 | 06:33 AM
jtammel's Avatar
Default Lower valve cover leak
Anyone has good suggestions how to make lower valve covers not leaking? I have already re-sealed upper breather covers and they are perfect. I also changed lower valve cover gaskets with OEM gaskets some 4 month ago but I can already see and smell leaking.
Is there any other option than to purchase a new set of OEM gaskets and re-install with crossed fingers ?
thanks
Old Sep 21, 2023 | 09:13 AM
NeedsWings's Avatar
Default Re: Lower valve cover leak
fresh set of OEM gaskets and make sure they are not twisted
The gasket was probably not completely seated when being reinstalled.
Old Sep 21, 2023 | 10:06 AM
dcskmail's Avatar
Check the torque 7ftlbs
Old Sep 21, 2023 | 10:40 AM
thanks
All I can say, is that I ordered the kit from Needswings when I fixed my leaking breathers. I took both valve and breather covers off the car, separated them, cleaned them extensively, let them dry overnight, then put on new gaskets and NEW BOLTS as well as using Max's technique in application of RTV. This was in 2016. No leaking even now, seven years later.
Total time: probably close to six-seven hours not counting drying time. I took my time, quick fixes don't last.
Old Sep 21, 2023 | 02:20 PM
jtammel's Avatar
When I re-did the lower valve cover gaskets, I took extra time to clean everything and make sure they were seated.
But it could be that during install process itself gaskets were loosened and that might be culprit.
Old Sep 21, 2023 | 02:21 PM
jtammel's Avatar
Breather covers are dry. I did basically how you described, let the RTV sealant sit for a while before installing the breathers and used new bolts. I guess that is why the breathers are dry.
Lower ones with the factory gasket is the issue.
Old Sep 21, 2023 | 02:27 PM
jtammel's Avatar
By the way, are you supposed to use sealant also to those breather vents where hose is connected? Becouse when I disassembled everything it looked like the hose side connection end had dried sealant on the grooves but I was not sure.
Old Sep 21, 2023 | 03:25 PM
I do not see the need, if the clamps are new. I think I remember seeing that as well, (it's been seven years) and I cleaned it off the cover, making sure my new clamps were tight - and yes, I put new clamps on.
Now, as to the valve covers, I have heard of some guys going back in six months and finding the bolts were loose and setting them to 5-7 lbs and things being OK after that.
Old Sep 21, 2023 | 03:34 PM
jtammel's Avatar
Umm.. clamps? Because my hoses do not have any clamps on breather cover end. That might be the culprit for oil smell as well.
Also I need to check the torque on the bolts.
Old Sep 21, 2023 | 03:40 PM
Mine had no clamps either, they did once I was finished.
Old Sep 21, 2023 | 03:46 PM
jtammel's Avatar
Thumbs up Re: Lower valve cover leak
Ok gotcha
BisB
24
Mar 14, 2016 10:44 AM
specialized1953
24
Feb 4, 2016 02:05 PM
Codyktt
Nov 17, 2014 04:42 PM
jediracer
Jan 28, 2013 11:04 AM
ri2300
Jan 17, 2011 09:34 PM
