Replacing battery
Old Nov 6, 2023 | 12:33 AM
williambuser's Avatar
Default Replacing battery
I had a problem with my battery it was constantly was going dead. So I replaced the battery as it was over 3 years old... I first took up the positive side and when I went to hook up the negative side it arked on me.... It was if I had a short...any ideas as to why the it was going this
2006 coupe standard transmission
Old Nov 6, 2023 | 12:39 AM
Default Re: Replacing battery
There are some capacitive loads in the car, an arc on connection is normal. The question is, what is the standby current?
I would encourage you to measure the current by doing this:
Close doors, close trunk.
Verify all lighrts are off.
Using a DMM, connect battery to positive cable thru the DMM set to 10amp scale.
Wait three minutes.
At the three minute mark, what is the current value? .055 amp or less is spec. If it does not exceed that, you are good. BUT WAIT THE FULL THREE MINUTES, any reading you get in less time is inaccuratly high, you must give the modules all time to hibernate before evaluating current.
Old Nov 7, 2023 | 12:21 AM
What is it greater than point .055.. By the way I'm assuming you mean DMM as a digital meter
Old Nov 7, 2023 | 12:21 PM
Yes, DMM is digital multimeter.
I don't understand what you are saying or asking here: "What is it greater than point .055". I will restate what I said: Any measurement over .055amp after three minutes is a problem.
Old Nov 7, 2023 | 01:12 PM
.056 is greater, so is 60,000.
zj93i6
Oct 13, 2016 06:10 PM
sive81364
Feb 26, 2011 07:55 PM
Speed8098
21
Jun 24, 2009 07:26 AM
buff5
Nov 12, 2008 04:27 PM
paradiso
Aug 19, 2007 09:41 PM
