Won't Start
Old Nov 9, 2023 | 04:28 PM
rbasm's Avatar
Default Won't Start
I went to put a new RCM in my Crossfire and the E Terminal wires separated from the clip. Does anyone have a color coded placement of the 5 wire back into the clip.
Old Nov 9, 2023 | 05:16 PM
Default Re: Won't Start
All of that is in the service manual, which can be downloaded by clicking this link:
https://www.crossfireforum.org/forum...ollection.html
DO NOT pull on the wires, use a flat blade screwdriver to get the plug to start coming out of the RCM jack - than pull ONLY on the connector housing.
MODERATOR NOTE:
Stop posting tech help requests in "New Members", this is area is for new member introductions.
Thread moved.
Old Nov 9, 2023 | 05:23 PM
rbasm's Avatar
Thanks Pizzaguy, this is perfect. I'll sleep tonight, lol
Old Nov 11, 2023 | 11:10 AM
rbasm's Avatar
Hi Pizzaguy, The wiring colors don't match the diagram, any suggestions. Richie
Old Nov 11, 2023 | 11:26 AM
They mostly match the manual. Remember the car is over 15 years old, colors fade over time - Im partly color blind (I have issues with red and green) and I think I see all of them.
Haveon't you ever used "Process of elimination" to obtain an answer? You start with the obvious ones and choose from the less obvious for the remaining.
Old Nov 11, 2023 | 11:51 AM
rbasm's Avatar
4,5,6 are my problem. Any idea if I miss match them, will they short out anything. 4 and 6 are asking for the same color but I have 2 red and greens.
Old Nov 11, 2023 | 02:43 PM
rbasm's Avatar
Hey Pizzaguy, Through the process of elimination 4 and 6 were crossed. I turned the key and she up and running. Thank you again for all your help!
HamdyHand
Oct 12, 2021 03:38 PM
Yellow Shore
Mar 19, 2021 12:00 PM
beachguy
Mar 9, 2017 09:35 AM
Helo Pilot
Jul 9, 2011 03:12 PM
ppro
Jan 7, 2009 04:15 PM
