Engine Restart After a Stall
Old Apr 13, 2024 | 04:25 PM
Root66's Avatar
Default Engine Restart After a Stall
I've been driving stick shifts for many years but every so often I get the clutch pedal and throttle out of sync and stall the engine. I can't simply turn the switch to the START position and restart (yes, the clutch pedal is fully depressed) but must turn the switch to the full OFF position, then to RUN until the fuel pump primes and then to START before it will restart. Is this normal operation or is there a problem?
Old Apr 13, 2024 | 04:51 PM
bluecoupe's Avatar
Default Re: Engine Restart After a Stall
As far as I recall that was the normal procedure with my manual Crossfire.
Old Apr 13, 2024 | 06:12 PM
Normal, it's part of the routine in the ECU that cuts the starter out at 400 rpm, they make the function "latching", I do not know why, it irritates me as well.
Old Apr 13, 2024 | 09:22 PM
Yes its normal.....If the engine stops you must turn the key to the left (off) to then restart the engine
tpellegr
Apr 3, 2018 01:15 PM
redhors66
16
Mar 22, 2018 03:25 PM
redhors66
Jan 3, 2018 08:56 PM
JaNeily
May 19, 2016 01:05 PM
chrisificti0n
Oct 13, 2014 12:00 AM
