Transmission filter locations
Old Apr 14, 2024 | 04:01 AM
My new weekend job's Avatar
Default Transmission filter locations
Hi I’m going to change my transmission fluid and want to do a thorough job, there are some really good instructions on here but I can’t find out where the additional two screen filters are located. The main filter is easy to find in the sump pan but there are two circular filters somewhere else, here is a link
thanks for your help
https://www.autodoc.co.uk/febi-bilstein/8008369
FEBI BILSTEIN 47282 Hydraulic Filter
Old Apr 14, 2024 | 09:43 AM
Nelson G's Avatar
Default Re: Transmission filter locations
Are those part of the Conductor Plate
Old Apr 14, 2024 | 11:26 AM
I don’t know but being round I thought they might be connected to the cooling system pipes
Old Apr 15, 2024 | 09:21 PM
zip439's Avatar
They are show on this parts as #13 diagram ; transmission filters
Old Apr 15, 2024 | 10:00 PM
Oldschool's Avatar
Doing the fluid/filter change on my 2005 SRT6 soon and want to verify that this is all good.
https://www.needswings.com/7226-tran...on-service-kit
Old Apr 16, 2024 | 09:37 AM
zip439's Avatar
I would not use the red fill cap locking tab. If used it will prevent you from running the dip stick down the tube in the future when you want to check your fluid unless you break the tab again. There might be a way to remove that tab without breaking it, but that is just another hassle to a job that should be a simple straight forward check the fluid level procedure. Simple reinsert the top cap and skip the locking tab.
Also the electrical connector may not work properly. Just slip the o-rings off the connector supplied with the kit and put them onto the electrical connector that is currently inserted into your transmission.
Those are minor things; That's a good kit go for it.
For more info as to the electrical connector see posts 12 & 15 and o-ring replacement in this post: new vice old electrical connector on transmission
Old Apr 16, 2024 | 11:32 AM
Nelson G's Avatar
I use a small screw driver and push the locking tab downward and catch it with my hand. Then I pull the cap off the fill pipe. Then I can reuse that clip again by aligning it at the top of the cap and when I replace the cap after it snug I push the clip down and it lock the cap.
Old Apr 20, 2024 | 03:39 AM
machfivecrossfire's Avatar
Im pretty sure they are filters for the servos. They are cleanable. No need to replace them unless they are broken. I remember seeing them when I replaced the conductor plate on my N\A.
WD40
Jul 6, 2020 04:36 PM
mikep330
Sep 24, 2010 03:40 PM
lioninavette
Sep 14, 2009 10:25 PM
aptiva
Jun 20, 2008 12:54 PM
sohc808
Feb 26, 2006 12:23 AM
