Loud thump when hitting brake in reverse
Old Jun 19, 2024 | 08:33 PM
ceasefire's Avatar
Default Loud thump when hitting brake in reverse
Spoiler
Old Jun 20, 2024 | 02:36 AM
Default Re: Loud thump when hitting brake in reverse
Originally Posted by ceasefire
Spoiler
It could be your flex discs or engine mounts.
Check your flex discs: With the car off reach under and rotate the drive shaft and see if you hear that clunking noise. Also check them for cracks or tears.
Check engine mounts: If you have help, have someone video your engine. (Don't let the person videoing stand in front of the car in case your foot slips off the brake pedal).
Press your foot on the brake and hold it there. Put the car in drive. With your other foot rev the engine a little bit. Now do the same with the car in reverse. Watch the video and see if the engine moves a lot.
You can also check it with the engine off. The second video shows how near the end of it.
Here are links to a couple of videos:
Old Jun 22, 2024 | 02:36 PM
ceasefire's Avatar
Replaced the flex disc with the unit from Needs Wings a couple thousand miles ago. I'm suspecting engine mounts. Suspension links?
Old Jun 22, 2024 | 08:58 PM
Might be time to set the front end up on jackstands and check the entire front end suspension. Have you recently done a front brake job? Any service to parts forward of the rear of the front wheels besides what you did before the sound was first noticed? After checking the front end for any play, come back with an update. Also, while the car is up on the jackstands, take a look at the flexdisk job to see if anything came loose. Good luck!
brhertel
Jun 4, 2022 02:19 PM
Bloo Ize
Aug 12, 2012 11:11 PM
bsb
Jun 11, 2007 11:14 AM
jrigsby
Nov 12, 2006 06:38 AM
azonie
Mar 15, 2005 08:14 PM
