Intake manifold
Old Jul 28, 2024 | 12:05 PM
Default Intake manifold
I am venturing to replace Intake Manifold gaskets and am having a hard time figuring out how to remove the brake booster hose from the manifold. Any info would be very helpful.
THANKS
Old Jul 28, 2024 | 02:46 PM
Default Re: Intake manifold
I figured it out and got the intake off. The entire front piece was blown out, Any ideas why? Maybe a faulty injector?
PS, the gaskets weren't the problem. LOL
Old Jul 29, 2024 | 12:50 AM
I'm sorry I don't have an answer for your question. If it were the engine block, I would think that you threw a rod!
All I can say is WOW!
Old Jul 29, 2024 | 07:49 AM
zip439's Avatar
Those backfires were more than it could take.
Did you check the EVAP solenoid for gasoline vice vapor?
Old Jul 29, 2024 | 09:54 AM
No yet but I will, thanks
Old Jul 29, 2024 | 12:30 PM
What would cause fuel in the EGR?
Old Jul 29, 2024 | 01:49 PM
zip439's Avatar
Our fuel injectors are just forward of the cylinders intake valve. For gas to reach the EGR it would need to back flow to the EGR at the rear of the engine where the EGR tube attaches to the intake. i can't see how gas could get to the EGR from the exhaust side. Definitely check all your injectors.
Raw gas at the EVAP solenoid comes from the charcoal canister at the rear of the car and usually caused by a bad shut off valve on the canister.
chevyboyac
Sep 16, 2020 12:23 AM
witchal
Feb 1, 2020 10:46 AM
brandoni
Jan 16, 2016 02:27 PM
coolx
May 3, 2014 08:24 PM
