Low fuel pressure
Old Aug 5, 2024 | 10:07 AM
Default Low fuel pressure
My Grandsons Crossfire stalls and the fuel pressure is only 40 PSI at the rail. Is the issue usually the fuel filter, fuel pump or both?
Old Aug 5, 2024 | 10:34 AM
DTMenace's Avatar
Default Re: Low fuel pressure
ZERACER
Change both, the filter and pump, due to the age of our cars. Buy the parts from Rob @ Needswings, since the majority of the parts on EBAY are from China.
There is a video about installing a new filter/pump, with all of the steps, disconnecting the negative, releasing the fuel pressure at the fuel rail, etc....
Be gentle when removing the plastic covering over the pump/filter.
Good Luck,
Dennis
DTMenace
Old Aug 5, 2024 | 03:54 PM
and your filter is also your regulator,
Old Aug 5, 2024 | 04:56 PM
Thanks, I figured.
Old Aug 6, 2024 | 12:53 PM
On all my crossfires I have installed a manual fuel regulator and fuel filter, i have found that with increased fuel pressure,
you do not need larger fuel injectors, With my V8 crossfire i ran 10.55 @ 132mph,,and with my V6 crossfire street tires, and no posi traction 12.008 @117.
If u go with a manual fuel reg. remember you must have a return line. jim
Castokrk
Nov 4, 2021 07:57 PM
aquarilized
Jun 4, 2020 09:50 AM
05srtsix
Jun 4, 2017 01:21 PM
Wolf_7
Apr 7, 2017 11:25 AM
beasticles
Mar 15, 2011 03:20 PM
