Engine sound
Old Aug 11, 2024 | 12:56 PM
Christiaan's Avatar
Default Engine sound
Recently discovered a strange sound, see video, is there anyone who is familiar with this "problem"?
Greetings Christiaan from the Netherlands
Old Aug 11, 2024 | 01:10 PM
Default Re: Engine sound
Originally Posted by Christiaan
Recently discovered a strange sound, see video, is there anyone who is familiar with this "problem"? Greetings Christiaan from the Netherlands
OUCH, that sounds expensive. Sure hope it isn't. Only 'guess' I have, is there something laying against the serpentine belt (or the alternator area)? Hope you find it.
Old Aug 11, 2024 | 01:19 PM
Christiaan's Avatar
I will look into that again, thanks for your response
Old Aug 11, 2024 | 02:30 PM
zip439's Avatar
remove the serpentine belt and turn all the pulleys by hand; inspect the belt
Old Aug 11, 2024 | 03:20 PM
Sounds like a bicycle with a baseball card on the spokes, for those of us old enough.
Old Aug 11, 2024 | 05:09 PM
DTMenace's Avatar
The OP is from the Netherlands....
Dennis
DTMenace
Old Aug 12, 2024 | 09:19 PM
As zip439 said pull the belt off and rotate all of them.
My guess would be the bearing in the "idler" pulley (the small pulley on the top of the engine) is going bad.
They are inexpensive and easy to replace.
Old Aug 13, 2024 | 01:38 AM
Christiaan's Avatar
Thumbs up Re: Engine sound
Thanks for your responses, I just ordered a new alternator. Locating the sound with a screwdriver to my ear brought me to the dynamo. All other bearings of the various pulleys are okay.
Greetings from Holland
Old Aug 13, 2024 | 08:42 AM
Jack G's Avatar
As a simple test spray some WD40 or an equivalent on the belt while running the engine. If as you indicate all the pulleys are okay and the sound disappears it is your belt that needs replacing.
Old Aug 13, 2024 | 09:39 AM
Christiaan's Avatar
the belt is not even 4 months old, I'm guessing the bearings of the alternator. But thanks for thinking along.
Christiaan
WD40
Jul 19, 2022 02:40 AM
TheStig
Oct 28, 2019 11:18 AM
jefftalexander
Dec 11, 2014 03:13 PM
Parallel Ice
Feb 6, 2013 09:50 PM
brewski
Oct 27, 2009 11:13 PM
