Need RCM replaced?
Old Sep 3, 2024 | 08:15 PM
hot57rambler's Avatar
Default Need RCM replaced?
I had a 2005 Roadster with 37,000 Miles. Probably the original RCM. I have a spare in the trunk. Today I went to start the car and it cranked and fired 3 separate times then wouldn't crank at all. I thought maybe the battery was low so I put the charger on and it seems to be charged. I use it pretty much so it's not sitting a lot. It will not open with the key fob. I had to use the key. they spoiler is down but the light is flashing, infact the parking lights flashed for a while after I tried to start it. Does this sound like an RCM failure? I didn't have time to try it tonight plus it's in the trunk which is locked. (I read the thread on opening the trunk when locked out). Any advice is appreciated.
Old Sep 3, 2024 | 08:45 PM
Default Re: Need RCM replaced?
Unfortunately, this sounds like the SKREEM issue. Search the forum, and pick one of the members who fixes or bypasses the SKREEM. Good luck!
Old Sep 3, 2024 | 09:32 PM
My roadster wouldn’t fire at all put in my spare RCM started right up. Skreem more than likely my day is coming
Old Sep 4, 2024 | 07:41 AM
Thank you. After I did some research it sounds like the SKREEM issue. Thanks for the help.
Old Sep 4, 2024 | 09:00 AM
Contact MSS, Mercedes Swap Shop.
Old Sep 4, 2024 | 09:05 AM
Has anybody had any experience with Precision ECU? They have a SKREEM delete module.
Old Sep 4, 2024 | 11:27 AM
Turned out to be a bad ground on the battery. Seems to be fine now.
Old Sep 4, 2024 | 06:20 PM
GLAD to hear this! Never heard of this issue like this before...
Old Sep 6, 2024 | 02:31 AM
Do you have secondary ground cable on your car?
You also might want to replace the ground strap going from the bell housing to the body.
Here's a link to a post about the grounds:
Secondary ground cable Installation & ground strap replacement.
Old Dec 19, 2024 | 06:19 PM
Shared by M60A3Driver
Check out this video on how to check your RCM.
It's by
tighed1
kerrycrossfire
Aug 16, 2024 07:45 PM
UnaidedPizza
30
Mar 5, 2023 10:14 PM
beachguy
Mar 9, 2017 09:35 AM
AlexParra
Dec 29, 2016 06:17 PM
rmcdaniel12
Oct 11, 2015 09:54 PM
