722.6 Connector Replacement Parts List
Old Apr 1, 2025 | 10:05 AM
Jack G's Avatar
Default 722.6 Connector Replacement Parts List
Planning to replace the MB A2035400253 data plug connector in my 722.6 transmission and would like to know the parts needed in addition to the connector. I plan on removing only the bottom pan and need the part #'s and/ or required replacement items. I will be ordering the kit through FCP Euro.
Old Apr 1, 2025 | 11:23 AM
Nelson G's Avatar
Default Re: 722.6 Connector Replacement Parts List
FCP has a kit that should include a filter, fluid, and a gasket for the pan. You should purchase a dipstick to measure the fluid level so as you add the new fluid you can make sure it is the right amount. Some people purchase a new dipstick tube plug. Some people change the conductor plate, I did not do that I just changed the fluid, filter, and connector.
Old Apr 1, 2025 | 12:03 PM
Jack G's Avatar
Thanks Nelson, I am doing what you did. My Roadster only has 40K miles. Installing the new connector, changing the filter, and cleaning the pan should be all that is needed.
Old Apr 2, 2025 | 07:28 AM
xintersecty's Avatar
This is a good post to read as you go through all the stuff needed to swap the connector. Might as well change the fluid depending on the years.
https://www.crossfireforum.org/forum...placement.html
Old Apr 2, 2025 | 09:20 AM
Nelson G's Avatar
Jack here is a post from FCP on how to do the trans and how to measure the fluid level.
https://www.fcpeuro.com/blog/mercede...-transmissions
gblack32
Jul 2, 2024 09:09 PM
roychez
Dec 10, 2021 06:58 PM
Doc78
Jun 27, 2021 09:21 AM
sitedata
Nov 30, 2017 01:57 PM
juddz
Sep 1, 2005 09:41 AM
