Crossfire rear cargo bulb
Old Apr 30, 2025 | 05:23 PM
LonRaynger's Avatar
Default Crossfire rear cargo bulb
I have a 2005 Crossfire Limited. The rear cargo light went out and I needed a new bulb. Every auto part store and also this forum says it takes a 6418 bulb. The problem is, it is too short and won't fit between the metal contacts. It just falls through. They can't be bent far enough to make it work. I did find a bulb (6411) that is the same size as the one that bunt out. It fits perfectly but it is a 10amp bulb while the 6418 is a 5 amp bulb. My dash light won't go out with this bulb and I'm wondering if it has to do with the different amperage. I checked every other bub everywhere on the car and can't find any other burnt out bulbs. I mean everywhere. Any suggestions? The 6418 bulb that is called for will not fit!
Old Apr 30, 2025 | 05:42 PM
Default Re: Crossfire rear cargo bulb
Did you check the small driving lights at the top of the headlight assemblies? If you can, post a photo of your cargo bulb fixture.
Old Apr 30, 2025 | 10:01 PM
I went through this problem myself a while ago when converting to LEDs.
The 6418 bulb is 36mm which is to short. The 6451 or 578 LED is 41 - 42mm and is the size that fits.
I think this is what you're looking for. I have this in the trunk of my roadster:
LINK to trunk bulb LINK to trunk bulb
Old May 1, 2025 | 10:07 AM
dcskmail's Avatar
I changed mine to led and added another light assembly on the other size , which in 2018 was still available at Chrysler parts
Old May 1, 2025 | 11:34 AM
LonRaynger's Avatar
Yes I checked those two bulbs by the headlights. I had to replace one a while back and it wasn't fun. They are both working thank goodness.
Old May 1, 2025 | 03:39 PM
Nelson G's Avatar
When I changed my bulbs to LEDs I found that some bulbs are more Mercedes size than Chrysler size. They are bigger I believe someone listed the size. This is the one I used:39MM DE3425 6461 LED Dome Map Courtesy Trunk Light Bulb, 2 Bulbs × 1
ZERACER
Nov 16, 2023 07:13 PM
sage210
Aug 30, 2017 10:54 AM
GTCayman
Dec 12, 2016 01:27 PM
TerryR
May 11, 2015 08:26 PM
tageier
Jun 9, 2013 04:18 PM
