How Should Banjo Bolt Sit In Radiator
Old Jun 13, 2025 | 12:06 AM
mikespine's Avatar
Default How Should Banjo Bolt Sit In Radiator
I replaced my radiator with a Nissens 2025007803.
My question is: how should the banjo bolt of the transmission coolant line sit on the radiator.
I have taken a picture from the bottom of the vehicle looking up. As you can see there are threads exposed.The bolts have been tightened, and I can not run them in any further. Should it be flush against the radiator.
I ran the car at idle with the heat on for about 30 minutes to get the thermostat temp up and to kick the fan on. There were no leaks noted.
If for some reason that the bolts should be flush to the radiator, do I need to take everything apart and start over as if I was replacing the radiator again.
If I disconnect the transmission lines from the radiator, will coolant run out or just a little transmissions fluid? I started connecting the transmission lines by hand tightening-hope I didn't strip them. Please let me know your thoughts.
Banjo bolt of transmission coolant line to the radiator. (taken from underneath the csr).
Banjo bolt of transmission coolant line to the radiator. (taken from underneath the car).
Old Jun 13, 2025 | 07:54 AM
mikespine's Avatar
Default Re: How Should Banjo Bolt Sit In Radiator
I took a better look at it today. The Mercedes Nissen Radiator 2025007803 has more threads exposed from the brass fitting compared to the original Mercedes BEHR 42039 radiator.
Nissen radiator has more threads exposed.
Original BEHR has less threads, appears more flush.
T voghel
Jun 19, 2017 06:06 PM
rfourt
Jun 11, 2014 02:32 PM
kolevski
Dec 14, 2011 07:41 AM
samo59
Dec 9, 2010 03:58 PM
TheHersh
Sep 18, 2010 03:42 AM
