Can we check the tranny fluid level?
Old Nov 25, 2005 | 01:46 PM
CrossfireLTD's Avatar
Angry Can we check the tranny fluid level?
This may sound like a dumb question to some but here goes. Can the tranny fluid level be checked? I did not see anything about this in the owners manual, I have a quarter size puddle of fluid on my garage floor, I believe it to be tranny fluid, I guess the infamous tranny O ring leak has found me. Any input would be greatly appreciated.
Old Nov 25, 2005 | 05:26 PM
bobs's Avatar
Default Re: Can we check the tranny fluid level?
The owner's manual says the tranny is sealed for life. But I find it vary difficult to believe there's no way to check the fluid level. Automatics usually have some kind of dipstick but if you have a 6-speed you're probably going to have to put the car on a lift and find the filler hole. The usual spec is that the fluid should come up to the bottom of the threads.
That being said, I doubt that a quarter-sized puddle will make a noticeable difference in the fluid level. I would recommend cleaning the spot and see if the puddle returns. Alternatively, you could put the car up on ramps or a lift and get underneath it and look for something that's wet.
If you don't have access to a lift (and since you're in Richmond), there's a place off the Midlothian Turnpike that rents lift bays by the hour. If you like I will swing by the place and get you a phone #.
Old Nov 27, 2005 | 09:49 PM
Cool Re: Can we check the tranny fluid level?
bobs,
Thanks for the offer, I will take it to the dealer on Monday. I am getting very close to my 14,000 mile service and will have it done a little early.
Old Nov 28, 2005 | 09:30 AM
catman's Avatar
I had the same symptoms and I just had mine in the shop to replace the o-rings on the 16th. I took about a day and a half and that is with them ordering the o-rings. No more leaks in over a week.
Old Nov 28, 2005 | 11:37 AM
Thumbs up Re: Can we check the tranny fluid level?
Problem fixed and "O" ring replaced. Dealer had the part in stock and I was in and out in less than 2 hours. This problem occurs with 300 and 300C also, Service Mgr. had the forethought to order some for the Xfire to have on hand just in case.
usprb1976
Apr 4, 2024 04:57 PM
PNA
Nov 12, 2020 04:44 PM
81's
Sep 13, 2015 04:34 PM
MickeyNasty
Sep 6, 2015 08:29 PM
chturner
Jul 24, 2015 04:47 PM
