Getting a new radio questions
Old Sep 25, 2006 | 07:52 AM
gibsonjunkie's Avatar
Default Re: Getting a new radio questions
There is a special plug that lets you plug in an iPod adapter, XM or Sirius adapter and a CD changer and control them all from the dash. The iPod adapter is about $49, the XM adapter (with antenna) is about $90 and the 12 disk changer is around $150.
Old Sep 25, 2006 | 10:29 AM
Can you tell me where I can find these?
Old Sep 25, 2006 | 10:37 AM
Crutchfield sells all of them.
Old Sep 25, 2006 | 05:12 PM
Interesting, I just contacted them and they tell me they don't have any of these products for the XF.
Old Sep 25, 2006 | 05:43 PM
Did you or anyone you know buy them there?
Old Sep 25, 2006 | 07:45 PM
I may not have explained it well enough. The adapters are all for the Pioneer model - not the OEM Crossfire model.
Here is the XM adapter
Here is the iPod adapter
Here is the CD Changer
Old Sep 25, 2006 | 09:08 PM
Got it, Thanks.
Old Sep 26, 2006 | 09:25 PM
Lightbulb Re:Installing a CD changer or Ipod connector for the OEM Radio
OK, I'm giving this another try.
Has anyone installed a CD changer, or know where to get the Ipod connector for the OEM head unit w/GPS?
Old May 28, 2007 | 09:58 PM
Bostonsrt6's Avatar
Originally Posted by crossfirefrank
I have a limited roadster and just used the vw connector and it worked fine. You do have to switch the power feeds around but it worked great.
Hey guys what do you mean by this? Also is there any pics on how to get to the amp and what wire to use?
Old May 29, 2007 | 01:10 PM
tashspop's Avatar
i just replaced my radio with the same plug. what it means is the constant power (yellow) and the switched power (red) need to be switched around or you will loose memory everytime you turn off the key.
Old May 29, 2007 | 02:44 PM
Bostonsrt6's Avatar
So...I have the harness for our cars...On the harness side there is the yellow constant power wire and on the navi there is another yellow wire which you connect...SO you are saying you take the yellow from the harness and connect to the red wire on the navi and vice versa from the navi to the harness??
Thanks...sorry in advance.
Old Aug 5, 2007 | 08:04 PM
Bostonsrt6's Avatar
Two Questions guys.
1) I ordered the Euro Antenna Adapter (Euro female to Motorola male) and it will not connect into the antenna on the crossfires end. Any suggestions?
2) It also looks like I need a dash kit in order to put my Avic n-1 in the place of the old radio. It looks like it will just go right in. Any suggestions?
Thanks!!!
Old Feb 6, 2008 | 07:22 PM
Crossfirerose's Avatar
Default Re: Installing a CD changer or Ipod connector for the OEM Radio
Did you ever get an answer to your question about an ipod connector for the oem unit with navigation? If so, what was the answer?:-)
Old Feb 7, 2008 | 10:23 AM
shark067's Avatar
Angry Re: Getting a new radio questions
What's interesting is they told me the same thing. I read on this forum to buy the VW plug and switch the power wires and it gets better -- so I go to the local Best Buys to get the connector and the install tech tell me it will not work with the stock infinity amp. I buy the connector anyways to give it a try. Took about 30 minutes to install the new head unit and it works great. I took it back to show the Best buy tech and he just scratch his head and said they told us it would not work. That's why I love this forum, you learn a lot of good information and mods.
Hmmm.... I went and talked to a Best Buy tech last night before I started reading this thread and they told me I needed a wire harness for '99 and up landrover.
Old Feb 7, 2008 | 01:59 PM
nox1s's Avatar
Well then, who are you going to believe?
Old Jun 23, 2008 | 03:30 PM
R/TommyB's Avatar
Originally Posted by MMZ_TimeLord
I did not intend to confuse you nox1s. If you want me to, I can point out exactly what wires are what...
What the heck is line #2, "Reverse Lamp signal"?.
smokey847
Nov 12, 2015 11:54 PM
jimf
Oct 10, 2015 10:22 AM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
Selbyl
Sep 26, 2015 04:15 AM
rmcdaniel12
Sep 21, 2015 10:58 AM
