Speed Sensor Wire Locaton
Need help. I have a base model roadster and is trying to locate the speed sensor wire. I read one of the post on this forum that stated is the one of the wires attached to the amplifier. The base model does not have an amplifier. I had a local installer install the JVC KD-Nx5000 head unit with the DVD player, blue tooth and navigation system. Everything works except for the navigation system. I think the problem is that the unit is not connect to the speed sensor wire. If any one has any ideas or know the location of the speed sensor wire I would appreciate your help. I have a 2005 base model roadster.
Thanks,
Robert
Thanks,
Robert
Thanks. I looked at this thread earlier and I think what it is saying is that I will have get the installer to run a wire because I don't think there one in the base model wiring harness. I know crutchfield sells a kit for about a $150.00. I will probably have to purchase this kit. Thanks for the info.
rmcdaniel12
Sep 26, 2016 05:37 PM
Crossfireone
23
Aug 25, 2015 04:56 AM
