Factory Alarm Chirp! Solved! Read!!!
Old Oct 20, 2008 | 09:07 AM
  #81 (permalink)
drivethruecp's Avatar
Default Re: Factory Alarm Chirp! Solved! Read!!!
Ok, I have NO chirp. Although my panic button very much works. On my stock window sticker (I am the second owner) it says Premium Security Alarm, but the dealer has the options features under my VIN and has no mention of this feature. But I went to the parts guy and he looked up my VIN differnetly and it indeed says Premium Security Alarm.
So I was arguing with them saying that I knew the part number of the Siren and that it is located under the cowl. They're argument was the Owners Manual has no mention of an alarm chirp (from the start). Anyhow they are taking another look at the siren and locating the alarm module if it indeed has one. I spoke to the only Crossfire qualified tech the dealer has, of whom worked on my car about it. He was cool about everything and are also replacing my liftgate latch (interior lights problem).
Any thoughts? I have a Limited and as the window sicker says (I have the original) the car is loaded. What gives? Is there any tests to see if the alarm has been disabled (which the mechanic suggested)?? Or to test its functionality??
Old Oct 21, 2008 | 01:28 PM
  #82 (permalink)
SRT6nTulsa's Avatar
Wiggle your front panel that hides the tow hitch. Mine has the siren, and it chirps whenever that hook is messed with. (I assume that's the alarm, and that's why there is a tow button.)
Old Dec 8, 2008 | 07:42 AM
  #83 (permalink)
huudoo's Avatar
i had to order a speaker mine went on the fritz,
quote - referenced "cricket on crack" sound
part 5124443aa
Old Dec 8, 2008 | 07:58 AM
  #84 (permalink)
maxcichon's Avatar
Arm the alarm with the passenger window down, reach inside and open the door.
Or arm it with someone inside and have them open a door from inside.
I think that should work. I have a roadster and the alarm has different features.
Old Dec 8, 2008 | 08:01 AM
  #85 (permalink)
maxcichon's Avatar
Originally Posted by huudoo
i had to order a speaker mine went on the fritz, no sound
part 5124443aa
That is the new, updated model with the chirp.
Old Dec 8, 2008 | 01:35 PM
  #86 (permalink)
No luck.
Yeh, this is the first thing I tried but doesn't alarm with lights or sound. Which is why I really think it is deactivated..?
Old Dec 8, 2008 | 03:51 PM
  #87 (permalink)
maxcichon's Avatar
No luck.
Or broken?
Old Dec 12, 2008 | 07:04 AM
  #88 (permalink)
huudoo's Avatar
i did not need a puller , when i got the nut off ....... LOL
just moved the wiper arm back / forward they came off
dam that sounded strange almost like when i was redoing my 8mm mauser stock
i posted ordered stripper ... need blo
Old Dec 12, 2008 | 10:48 AM
  #89 (permalink)
Mimi05SRT6's Avatar
Wow,....Excellent! This forum keeps getting better and better with all this valuable information. We need to have all the how to's placed into that one thread to make it easier to look up. Thanks for letting us know about this! Now I should still be able to get mine fixed under the warranty which will expire next July.
Old Dec 17, 2008 | 08:51 AM
  #90 (permalink)
So I just got my car back from service where they replaced my rear latch to fix my interior lights problem and it was also rateling. Now the alarm works!! But NO CHIRP!! : ( and the dealer provided me with all of this documentation on my factory alarm about it arming/disarming with no mention of an audiable chirp. Ugh! So I'll picked up a radioshack buzzer to install with the relay in the fuse box.
Question: if I use the fusebox relay and wire it with the siren rather than the buzzer I wonder how it'll sound... Any thoughts?
Old Dec 26, 2008 | 03:54 PM
  #91 (permalink)
Veloce's Avatar
Help!
I have the the 5124443AB as shown below
Other than internal electronics, will it fit on the car? I really don't want to take the car apart and then find out it won't work.
The photos of both the old siren and the new 512443AA show a threaded hole for a stud. The one I've attached has a stud. And, yes, I've checked under it and it is solid plastic.
Help?
Old Feb 17, 2009 | 02:05 PM
  #92 (permalink)
topdown's Avatar
my panic alarm sounds exactly like a "cricket on crack" the dealer said they never seen a problem like this. i hope all it is is replacing the siren. the truth is that if anyone else has had this problem than i am glad i am not the only one..
Old Mar 22, 2009 | 02:08 PM
  #93 (permalink)
Veloce's Avatar
I installed the new alarm today and it functions exactly as described...I have "chrip"
I did have to find a nut for the new siren, but otherwise it works as described! The only downside, if you want to call it that, is that the security bolt is no longer used, but I figure if a thief is getting that far into my car he/she would have a security torx set anyway.
I used a battery post puller to take off the wiper blades. Marked where they went with tape before total removal, though.
Thanks for thread.
Old Apr 28, 2009 | 10:26 PM
  #94 (permalink)
topdown's Avatar
just got to dealer today to fix cricket sounding panic alarm. they said they needed to order new "horn" from germany, could take 4 days till they get the part. i hope that fixes the problem, the regular horn works fine but the panic alarm sounds like it just blew, kind of like when the insides of a speaker/amp goes out....anyone have similar experiences?
Old Dec 20, 2009 | 05:35 PM
  #95 (permalink)
HOT WHEELS's Avatar
Hello, I'm super confused,Check the part # and the "PRICE",The new one is part #5124443AA, but the replacent is part #5124443AB, as the link says ( Chrysler Parts Direct - Chrysler, Dodge, Jeep Parts and accessories ), and the price! OMG, you got a bargain.
Thanks ,I'll surf for prices!
Home Log In Your Account Catalogs Auctions Shopping Cart Order Status Contact Us About Us Policies
Select Catalog:
Search by OEM Part Number:
Multi-Part Search
Supersession Information
Part number 5124443AA was superseded by part number 5124443AB.
Collision Catalog
Item Number MSRP Core Price Price
5124443AB $194.00 $0.00 $151.32
Electrical - Alarm system - Alarm horn
Alarm horn 2004 - 2008
Add to Cart Contact Us
OEM Catalog
SIREN ALARM
Powered by Trademotion HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Old Dec 28, 2009 | 09:54 AM
  #96 (permalink)
HRD2MIS's Avatar
I just found out the same thing! I was a little upset to find the replacemet part is $150.00 vs. The previous horn being only $60 I had to order a key today and figured what the hell I'll go ahead and get the horn an he wanted $191.00 and so I searched online and all I can fin is the $150 one. I don't know about you guys but if im going to start spendig that kinda money I might as well get a real alarm with remote start for just a hundred bucks more or so.
Old Dec 29, 2009 | 08:24 AM
  #97 (permalink)
Very good point actually. I'd prolly go for the Viper Smart Start, were you can use your iphone as the remote. But only if I didn't have to put my key in the ignition to drive??
Old Jan 1, 2010 | 02:58 PM
  #98 (permalink)
Darticus's Avatar
Do all crossfires come with the alarm? I have a 2008 roadster limited and wonder if there is a factory alarm in it as I only have the lights blink when I lock it. Should I have a chirp? Ron
Old Jan 1, 2010 | 03:43 PM
  #99 (permalink)
corfire's Avatar
The Crossfire wasn't originally set up to have a lock/unlock 'chirp' or tone. However, if you are a bit handy, you can get one for about $5 by following the link to my old thread.
https://www.crossfireforum.org/forum...lert-tone.html
Also, several members have been able to get the chirp by replacing the alarm siren with a new one (different part number) as indicated in this thread. That process does appear to be getting expensive.
Old Jan 1, 2010 | 05:02 PM
  #100 (permalink)
Darticus's Avatar
If the alarm siren works fine in my car for security and panic why would I replace it to chirp? Why don't it just chirp? Ron
