srt-6 subs?
Old Apr 22, 2008 | 06:42 PM
Voyager's Avatar
Default srt-6 subs?
there is an awful lot of bass from the back seats but when i look behind the seat there are just little vents that are like 3 inchs by 5 inches is that whats producing all the bass? if not what is?
Old Apr 22, 2008 | 06:49 PM
Moparrbust's Avatar
Default Re: srt-6 subs?
You must have a special edition Crossfire..............the "subs" behind the seat in mine barely emit(sp) anything that even closely resembles bass.
The location you speak of IS where the stock "subs" are located though..........behind the vents.
Old Apr 22, 2008 | 06:50 PM
Voyager's Avatar
is the srt-6 a special edition crossfire and what size are the factory subs?
Old Apr 22, 2008 | 06:58 PM
Moparrbust's Avatar
Not that I know of.........I was just BSing. The factory subs are 6'' I believe. I didn't like mine so I added a 10'' sub and 300watt amp in the back to provide a little more thump.
Old Apr 22, 2008 | 07:24 PM
Voyager's Avatar
well im trying to do a stealth job where everything in the car looks stock. so im planning on upgrading the subs and hiding a couple small amps in series to power them. so before i rip the speakers out i want to know the size of them
Old Apr 22, 2008 | 08:33 PM
nascarhq's Avatar
Thumbs up Re: srt-6 subs?
The limited edition and srt comes with 240 watt infinity amp and subs,they are small but they kick butt.
Old Apr 22, 2008 | 11:38 PM
GatorLCA's Avatar
I'm pretty sure they are just the mid range speakers from any type of component speaker set. It does produce bass but I think it's there to fill the car up with sound rather than not have any, kind of plays tricks on your ear. However, if you do crank it up they will buzz your butt
Old Apr 23, 2008 | 06:42 AM
SRT-6'er's Avatar
Are they 6'' or 6 1/2''??
Old Apr 23, 2008 | 06:44 AM
FYI There are no differences in the sound systems between SRT6 and Limited.
Old Apr 23, 2008 | 05:55 PM
Moparrbust's Avatar
Mine must be faulty then because my first complaint about the car was the fact that it had NO bass at any level with the factory system. I tore the car apart and saw the the factory "subs" looked to be mid range speakers at best and are mounted at a weird angle(probably for better sound) behind the vents.
Old Apr 23, 2008 | 06:32 PM
nascarhq's Avatar
i would get it checked out. make sure you have the bass settings on the reciever cranked too.play the song diddy rock by diddy and timbaland and if that doesnt shake the gel in your hair,somthings wrong with your amp.
Old Apr 23, 2008 | 06:35 PM
Moparrbust's Avatar
Yeah; I've tried playing all sorts of BASS filled songs before to no avail. I don't think the dealer would like to troubleshoot my stereo now that I have an aftermarket deck, 10'' sub and 300watt amp. I also still have the same HORRIBLE radio reception on almost all stations that I had with the factory deck. Someday I'll solve that problem as well.
Old Apr 23, 2008 | 07:49 PM
Voyager's Avatar
haha good luck with that! i think part of the problem is that the antenna is hidden and does anyone have ANY pictures of what is going on with the wall behind the seats so i have some idea of what it looks like before i rip all the carpeting out and get a surprise the pdf file of how to take everything off is not doing it for me. and ive heard like 10 different answers of what speakers/subs are in the back! and where is this 250 watt amp?? that is a beast for a stock setup
Old Apr 23, 2008 | 07:55 PM
nascarhq's Avatar
i think the amp is under the passenger side floor.thats where they put in my gps and audio control unit.
Old Apr 23, 2008 | 08:01 PM
Voyager's Avatar
are you serious!?!?!!?! i would NEVER have found that unless i started chasing wires which trying to do with a stock wire setup can be extremely confusing. wow where in the floor? behind the seat or what? thanks for all the help everyone im finally figuring out that this speaker setup is quite interesting
Old Apr 23, 2008 | 09:09 PM
nox1s's Avatar
it's under the passenger footwell. roll up the carpet and you will see it... the gas tank is behind the wall, and as such, do not drill into there.. bad bad bad things happen..
Old Apr 23, 2008 | 09:18 PM
Voyager's Avatar
haha why i would be going around trying to figure out what is going on with the back wall with a drill is beyond me. but i will keep it in mind if i do get upset and decide to drill random holes into things ill stay away from that part of my car! why is there speakers right above a gas tank. what would a side collision do to that area
Old May 17, 2008 | 07:30 PM
uniquemethodz's Avatar
I'm looking to change the factory subs on my SRT-6. I have seen that JL and Kicker both make a small 6.5 inch sub. I'm not an audio guru so I would like some help if possible:
1. Will they fit?
2. If so is there enough airspace to get a decent sound?
3. Any other brands or suggestions would be greatly appreciated
Here are the specs in case you were wondering....
JL 6w0 specs
Nominal Diameter: 6.5 inches (165 mm)
Mounting Depth: 3.5"
Continuous Power Handling: 75 Watts
Voice Coil: 1.25" diameter, 4-layer, Kapton former
Available Configurations: 4 ohm (Single Voice Coil)
Xmax (one-way, linear): 0.285" (7.2 mm)
Sealed Enclosure Range: 0.15-0.20 cu.ft. (4.3-5.8 liters)
Ported Enclosure Range: 0.20-0.33 cu.ft. (5.8-9.3 liters)
VRCtm Technology: YES
Kicker 08 CVT 654
Power:
150 Watts RMS
300 Watts Peak
4 Ohm Single Voice Coil
Injection molded polypropylene cone woofer
Ribbed santoprene rubber surround
Spiralead" tinsel-lead technology
Spring-loaded binding posts
Slender basket
Shallow-mount
Uniplate" backplate and pole
360° Back bracing
Perimeter venting specialized four-layer high-temp single 4 ohms voice coil
Woofer Surround Santoprene Rubber
Woofer Composition Injected Molded Poly
Frequency Response: 30 Hz - 350
Mounting Depth: 2-13/16"
Mounting Cutout: 5-9/16"
Sensitivity: 85 dB
I posted this on another thread but nobody responded so I'd thought maybe I would try here... Thank Guys!
Old May 17, 2008 | 08:31 PM
maxcichon's Avatar
You might be interested in the fountains of information in this thread:
https://www.crossfireforum.org/forum...ead.php?t=9938
Good luck.
Old May 18, 2008 | 09:05 AM
Mimi05SRT6's Avatar
I get way more bass than I need from the 2 factory subs. So I'll never be replacing them unless they actually go out on me.
usprb1976
Apr 4, 2024 04:57 PM
blackpepper
Dec 18, 2021 06:17 PM
miscetera
Oct 5, 2015 11:40 AM
Jocko124
Sep 29, 2015 11:39 AM
Jocko124
Sep 5, 2015 09:10 PM
