My panic button no longer works?
Old Mar 26, 2009 | 05:36 AM
KimPossible's Avatar
Default Re: My panic button no longer works?
I had the same thing. Dealer told me it was some kind of a loose wire & it literally took 5 minutes to fix. They knew exactly how to fix it when I told them what was going on. They didn't even pull it in a bay, just fixed in the the drive, tossed me my keys & I was all set. No problems since the fix almost 6 mo ago - not that I need my alarm a lot. I didn't have door locking chirps either until the fix.
Old Mar 26, 2009 | 07:49 AM
Hawk Monster's Avatar
Thanks that was the first thing they did. The reason I know is when they gave me a ride home I had to give my spare key to the driver so they would have both keys to work with. In the warranty history their is no mention of TSBs being performed.
Old Mar 29, 2009 | 08:49 AM
The body control module (BCM) will not be here till Monday but I found the following interesting.
Dealer told me they had to have a part sent/rented from Chrysler in Michegan so they could have an interface between their computer and the BCM in order for them to download new firmware into the body control module. I was told that it is too expensive to own for the limited number of Crossfire's they deal with. Does this sound right? Has anyone heard of this before?
Old Mar 29, 2009 | 10:19 AM
Paul Bosslet's Avatar
Is this the part that the Dealer replaced?
alarm siren 1028006, FP number 5124443-AA
It is where the chirp originates when locking the car.
Good luck with the problem.
Old Mar 29, 2009 | 02:09 PM
No the siren module is OK and so is the siren. They replaced the Centrol Locking module and the SKEEM and a bus connector. Tuesday they are replacing the Body Control module after it is reprogramed with new firmware. It does not appear to be the quick fix I had seen previously on the Forum. Glad I did bring it in for rhe work. It is still under warranty. I will post part numbers when I get them.
Old Mar 29, 2009 | 02:49 PM
maxcichon's Avatar
Thanks for the update, and sorry for the poor advise.
Old Apr 4, 2009 | 09:10 AM
Forgive the rant but it is now 6 weeks and still no progress on fixing the panic button BUT... I have come to the conclusion that Fiat is crazy for doing a deal with Chrsyler and Meredes must have thought they could not wait to divorce Chrsyler. When attempting to program the new Body Control Module the dealer found that the NEW SKREEM was not programed by Chrysler with my complete VIN #. It only had my first 3 digits. It will be six weeks to fix a panic button. Living in a rural town is great until you need to get parts or service. I have AAA plus so I can get my Mercedes towed to Phoenix to have it worked on for any real repairs needed.
Old Apr 22, 2009 | 09:46 AM
Well this saga started 2/27/09 and it is almost 8 weeks latter and the panic button is still inop. Today they are trying to get the third Body Control Module to accept the program. If this fails they (Chrysler) is supposed to fly in an engineer. Honestly I am not holding out much hope that the third time will be a charm. Car drives and works OK except for the panic button BUT this could be a major problem in the future if they can't program the BCM to accept new parts.
Old Apr 22, 2009 | 06:53 PM
Well the body control module is still not accepting a program. They even tried to disconnect the transmission module which was blocking the BCM from accepting the new program. I'll know more tomorrow hopefully.
Old Sep 26, 2009 | 07:31 AM
LugNut's Avatar
Hawk: Ever get this fixed? If so, what was needed? Thanks.
Old Sep 26, 2009 | 10:18 AM
Sorry. I thought I posted the results. It was NOT anything physical. It was a programing error when the car was built. They had to go in and delete all the program data and replace the country of orgin to the United States. My orginal dealer was unable to program the module due to lacking the correct equipment so they replaced all the parts. It must have cost Chrysler a bundle. Some of the parts where replaced 2 and 3 times. This dealer also gave me a new key. After this dealer was closed by Chrysler, I took it to AirPark Chrysler and they fixed it in a day. I live in a riural area and had to drive 3 hours one way to take the car to AirPark but it was worth it. Hope this helps. If you are having the same problem perhaps I could give you some options since I worked on this problem for over 6 months.
Old Sep 26, 2009 | 04:13 PM
So the moral of this tale is that when the panic button does not work don't panic as it may take 6 months to fix.
It just shows that some dealers change parts hoping to hit the right one by luck, the customer would be asked to pay for these items as they would not eat the cost themselves.
Old Oct 28, 2009 | 07:07 PM
gfields14's Avatar
Just curious as to what your recommended course of action would be for some one in a similar situation?
My 04 with 60,000 miles electrical system is going insane. First i noticed weird tendency's with my abs light, but now its all messed up. Luckily this doesn't affect the driving, but is an insane nuisance . Primarily among the other issues lie the spoiler not functioning correctly (has a blinking red light, and wont stay down) and the warning lights go crazy when you honk the horn ( weird right?). If anyone has a semi easy at home fix, lmk cause i really don't want to go through the hassle of dealing with the dealership. Also would any of these issues be covered by the 70,000 mile power train warranty?
Old Oct 28, 2009 | 07:44 PM
How old is the battery in the car? Failing batteries cause the spoiler issue and others.
Old Oct 28, 2009 | 10:19 PM
I would call dealer to see if covered. In my experience complex electrical problems are NOT a diy project unless you have alot of experience, knowledge, etc.
Old Oct 28, 2009 | 10:23 PM
LugNut's Avatar
My vote for the main battery needing replacement too. Seems to have fixed my alarm problem.
Old Oct 28, 2009 | 11:03 PM
tighed1's Avatar
Just for the record both of my car's panic buttons don't work.
I know for sure that the coupe alarm used to work. Not sure about the roadster.
Haven't tried to fix it. Was hoping there might be an answer here.
Oh well...
Old Oct 28, 2009 | 11:50 PM
  #38 (permalink)
gfields14's Avatar
Ill go test the battery tomorrow, it doesn't look the old owner had replaced it in a while.
Old Oct 29, 2009 | 08:53 AM
  #39 (permalink)
When you ask a question it would be good to know the year of the car at least.
Old Oct 29, 2009 | 08:56 AM
  #40 (permalink)
Oh well...
You are being modest, of all the people on this forum that problem should be a walk in the park for you.
I am going to pull the board today and study the solder joints. Thanks again.
