My panic button no longer works?
Old Oct 29, 2009 | 10:34 PM
  #41 (permalink)
gfields14's Avatar
Default Re: My panic button no longer works?
Just curious, would oreillys or an auto parts store be able to tell me if it's a baterry issue if I brought my battery in?
Old Oct 29, 2009 | 11:06 PM
  #42 (permalink)
amb7247's Avatar
they should. I think they have a machine that can check the status of a battery and let you know if you need a new one.
Old Oct 30, 2009 | 06:49 AM
  #43 (permalink)
LugNut's Avatar
"Just curious, would oreillys or an auto parts store be able to tell me if it's a baterry issue if I brought my battery in?
they should. I think they have a machine that can check the status of a battery and let you know if you need a new one."
Yes, but if your battery is more than about four years old, or you are having any of the weird alarm, etc. problems reported on the site, then just go-ahead and replace the battery. Mine seemed fine, but no! It had to embarrass me badly at work.
Old Oct 30, 2009 | 06:31 PM
  #44 (permalink)
gfields14's Avatar
Update: took the battery in, and it had gone bad, but sadly replacing it was no cure-all. Although the issues aren't persistent like they used to be they still occur when there is a large load on the electrical system( turning the brights on or honking with the lights on) any of the following symptom may occur.
A. The spoiler pops up and becomes immobile( even after the load is removed)
B. the warning lights on the dash light up like a Christmas tree(not all of them, but what appear to be random ones )
c. The drivers side light dims and the driver side blinker will not work (only when excessive load is applied).
Any help would be appreciated.
Old Oct 30, 2009 | 08:52 PM
  #45 (permalink)
tighed1's Avatar
Now that you have a good battery go back to Autozone (or where ever) and have them check out yer charging system (free).
If that all checks out I'd start looking at ground connections. I'd loosen them clean them and re-tighten all that I could find.
Old Oct 30, 2009 | 10:35 PM
  #46 (permalink)
+1
There are quite a lot of grounds on this car, do the obvious ones and then look harder. Bad grounds do not work at all well with a heavy load applied to them, just plain lazy I guess.
Old Oct 30, 2009 | 11:14 PM
  #47 (permalink)
LugNut's Avatar
I'd think about replacing the battery cables, and as described above, making sure the ground(s) are good.
On old Mopars, I'd also be looking for corrosion on the bulkhead (through firewall) connections.
Old Nov 1, 2009 | 01:00 AM
  #48 (permalink)
gfields14's Avatar
oAre there any decent wiring diagrams on this site for the electrical system as far as the dash connections go?I tried searching but could only find links to the manual which is less detailed than what i was looking for. I want to make sure I can get it all back together right before I dive into this.
EDIT: Found this one http://homepage.mac.com/gregmeach/XFire/ has some good diagrams
Old Nov 1, 2009 | 08:38 AM
  #49 (permalink)
EDIT: Found this one Crossfire Repair Manuals has some good diagrams
I always thought that was the shop manual, it just seemed the sections were titled differently.
Old Nov 1, 2009 | 10:33 AM
  #50 (permalink)
gfields14's Avatar
Another interesting tid bit : I've learned that if I turn the key to the on position and then turn on the lights the car will start. ( without actually turning the key all the way) and no I've not done anything under the dash where stuff could get switched, although the car could have came this way as I just bought it a week ago. ( luckily I got the gold warranty from the dealership )
Old Nov 1, 2009 | 11:08 AM
  #51 (permalink)
Warranty? take it back why bother to waste the time, if you screw something up your warranty will be worth nothing.
waldig
Jul 31, 2017 09:46 AM
spoiler
Sep 2, 2015 08:56 PM
gtjl
17
Jul 22, 2015 06:28 PM
rmcdaniel12
Jul 21, 2015 11:35 PM
66L72M21
Jul 15, 2015 04:23 PM
