flicker noise from the speakers when listening to the radio... Need help
Old Nov 14, 2008 | 06:13 AM
martosh79's Avatar
Default flicker noise from the speakers when listening to the radio... Need help
Hi,
I have a problem with my radio.....
It makes a wead noice when listening to mysuic or speach... The cd's works fine but when listening to the radio you hear a noice from speakers like the cables are not well togheter or that like the antena is not well connected....
What can I use to open and take the radio of? And what can the problem be??????
you hear a flicker noise from the speakers
Best regards,
Old Dec 5, 2008 | 11:29 AM
ppro's Avatar
Default Re: flicker noise from the speakers when listening to the radio... Need help
Here's the tool - about $3 at Wal*Mart
Check to see if you have a problem with the antenna connection - note that it is not a USA style connector and has a locking connection that has to be released to disconnect - don't just try to pull it off - you might break it.
You may also have a problem with the antenna connection to the rear window. You'd have to refer to the factory manual to trace that down.
Old Dec 5, 2008 | 06:46 PM
maxcichon's Avatar
Martosh-I think there's a WalMart in Espoo.
Best of luck!
Old Dec 5, 2008 | 08:34 PM
Waynesworld's Avatar
If his AV pic is correct he has a roadster, & just might of done somthing in the trunk to the antana there?? Look at that first?
Old Dec 6, 2008 | 10:35 AM
eganders's Avatar
Originally Posted by martosh79
Hi,
Best regards,
With the car parked (not moving), does the noise happen, or is it only when the car is moving?
Does the noise happen only from the radio, or also when playing CD's?
Does the noise come from all 4 speakers (turn the balance control to the right or left, and the fader control to front or the back) or just some of them?
Old Dec 6, 2008 | 12:05 PM
maxcichon's Avatar
Fader?
Old Dec 6, 2008 | 03:26 PM
Squirrel Crusher's Avatar
Is your radio reception great when you don't have your cell phone in the car?
Old Dec 16, 2008 | 02:35 AM
martosh79's Avatar
Hi,
the problem occures when I am driving and also parked. It doesn't happen when I am listening to a cd, so i suppose it has to be something with the antenna. I do have a cabriolet, so I will check the connections in the trunk first and also behind the radio. Will see what it's exactly.
Concerning the mobile phone, even if I switch it off totaly, the flicker noise is still remaining. Still wondering what that can be. For the first 6 months that I had the car, there was no problem. Now it happens everyday.
Thx all for the infos'
ty_ty37
Jun 27, 2024 10:42 AM
usprb1976
Apr 4, 2024 04:57 PM
blackpepper
Dec 18, 2021 06:17 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
