Convertible top issues
Old Sep 22, 2009 | 12:50 PM
Vegas Xfire's Avatar
Question Convertible top issues
Need some assistance from all you Crossfire experts - I have an '05 Crossfire convertible, been having problems with the top - it won't go down. Checked & double checked the trunk area to make sure the divider is in place correctly. I will work for a minute, then after driving it for a day or so...the top won't go back down. Took it to a shop that specializes in electronics, and he said there have been issues with this car & it's top - anyone have more info than this?? This is perfect topless weather in Vegas right now! Thanks!!
Old Sep 22, 2009 | 01:03 PM
rcompart's Avatar
Default Re: Convertible top issues
Check, double check and then check once again that the little switch on the driver side where you put the cover up is locked in place. If that switch isn't pressed down, it won't let you operate the top. Hope this helps.
Old Sep 22, 2009 | 08:22 PM
Not sure what little switch you're referring too? I looked all over the driver's side...and didn't see anything. The convertible top control is on the middle console.
Old Sep 22, 2009 | 08:28 PM
He's referring to the switch on the drivers side Ianthe trunk where the partition is. It can be temperamental.
Old Sep 23, 2009 | 11:55 AM
Iamfink2's Avatar
When you unlatch the top and push the top up do the windows go down automatically? If not its the switch in the windshield header I have the same problem. I have the switch I just have to install the thing.
ZERACER
Jul 7, 2020 10:21 PM
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
mike28117
Jul 17, 2015 01:59 PM
Bayukbros
Jul 17, 2015 11:21 AM
