Upgrade to Nav Radio
Old May 20, 2010 | 05:37 AM
stlouisramsfan's Avatar
Default Re: Upgrade to Nav Radio
Originally Posted by stlouisramsfan
Thanks
I have the location that each end needs to go, i just need the 2 wires.... i 180 said he has them, i will probably get them from him, when he gets on the forum again....
Good news guys
180 (Dave) has located the wires, shipping out soon! With any luck, my next dumb questions will be how to get the dash out... Lol, thanks for all the help to date!
Old May 20, 2010 | 12:55 PM
SNAKEWOLF's Avatar
Just Be Carefull The Instructions Are Not As Simple As Sugested You Will Need To Use Connector Color And Location In Service Manual Too
Don.t Get Upset Just A Suggestion Since I Did It With No Wires Supplied
Old May 23, 2010 | 09:05 AM
Wasn't upset, the answer you gave wasn't what I needed for the question I thought I asked... Anyway, the additional adapter worked and the nav unit has replaced the original stock cd player. Waiting on the gps antenna (from singapor) the 2 wires from 180 (from canada) and the ipod adaptor (usa I believe) its a worldly car with parts from all over the world... Lol I will let you know of the next group of problems...
Old May 27, 2010 | 07:48 AM
GPS antenna and the 2 additonal wires came yesterday... Installed the antenna and it appears to be working (shows correct compass on display) tried to insert the 2 wires into the factory connector but didn't seem to want to fit... Kinda dark last night so I will try in daylight tonight... It wants to bounce between east and west disc... I am near st. Louis which is the line, this unit came from cali and when I ask for POI it wants to go to the west disk...Thanks for any tips, the help speeds up the process
Old May 27, 2010 | 06:12 PM
SNAKEWOLF's Avatar
When You Know It Is Installed Right Then Reset The Radio And Nav . I Had To Reset I Am In Fla And Radio Came From Ca . The Procedure Is In Nav Manual Free On This Forum.
Old May 27, 2010 | 07:50 PM
Thanks snake, I stumbled across that a little while ago... Now it finds the local POI... I still need to solder in the reverse and speed wires, I will have some time saturday morning and hopefully that will staighten this last malfunction... It tells me the initial direction but nothing else... Getting close... I really did this for the IPOD set up... Btw, with the usb setup for the ipod deal, do you guys think I could load the GPS disk's into a thumb drive so I don't have to deal with putting the disk in the front cd loader?
Thanks again and in advance
Old May 27, 2010 | 09:15 PM
........ I really did this for the IPOD set up... Btw, with the usb setup for the ipod deal, do you guys think I could load the GPS disk's into a thumb drive so I don't have to deal with putting the disk in the front cd loader?
No, I think the Ipod mimics the CD changer, the nav CD has to go into the head unit and it does not work in the changer. Ive been wrong before but ....
Old May 28, 2010 | 06:32 AM
bluecoupe's Avatar
I believe Dave is correct on this one. I have the ipod controller solely for the USB facility. I've run both the Nav feature and the CDC feature at the same time, so they work independently of each other. I wouldn't want to give up 2 CD slots on the USB for the Nav feature and it would also render the random track option useless. I think Rudy would have the final answer on this, but don't see how it would be possible?
Old May 29, 2010 | 08:59 AM
ok guys, i think i am to the home stretch... finally taking some time to open up the kickplate and install the two wires.... i found a "light green/white wire on the larger connector going into the amp.... matches up with the pic of the instructions (says dark green/white) but i think its right...
now the reverse wire is a different story, says i am looking for gray/yellow, i see a gray, a gray/black... but no gray/yellow i am goung to get a diffderent flash light to see if i can get a better look at it....
thanks
Old May 29, 2010 | 09:32 AM
here is a couple pics....
the first is showing the green/white... on one set of instructions (http://www.majormotorshotrods.com/_d...tall.pdf)dated 2005 it says to use this one... i believe this one is correct for my car (2006)
now on one dated 2004 it says another spot in the connector....
on the second pic, i am looking for the mysterious gray/yellow wire.... found gray, gray with black stripe and gray with red stripe.... both sets of instructions say the same thing.... help please.... lol
Old May 29, 2010 | 09:53 AM
Where are you getting the 2004 instructions from?
Old May 29, 2010 | 09:59 AM
found them on here i believe, i have attached a copy....
File Type: pdf
Old May 29, 2010 | 10:31 AM
For the back up signal, go to the trunk and look for the color of wire that goes to the back up lamp. that should be what you want.
The color here is the same color wire you will look for under the passenger side footwell.
Old Jun 3, 2010 | 09:11 PM
went for a cruise tonight and the nav must of synched itself up... worked both places i was going, seemed good enough for me... did not hook up the reverse, i think it will be good as it is.... thanks for the help guys, looking forward to the ipod feature (thats really the only reason i upgraded, i like to keep things looking factory)
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sterling57
Apr 11, 2016 06:11 PM
brandoni
Sep 30, 2015 07:48 PM
Sep 28, 2015 07:40 PM
Selbyl
Sep 26, 2015 04:15 AM
