Cool trick with the factory nav radio...
Fom one Howard to another ....
As far as I can find by reading thru the manuals, the only adjustment that can done to the LCD display, is to set it at always positive, always negative, or Automatic. Maybe there is someone else that has accomplished this by other means and will chime in .... cheers Howard
Thanks for the input re the sunglasses. I recognize there will be issues viewing with sunglasses, but my real issue is it's hard to see even without them. It used to be pretty visible during daylight (especially without the glasses) but now it's very difficult. I expect I did something inadvertently when programing the unit but I haven't been able to make the screen brighter, even though the manual says you can in the OPT function. If anyone has had similar issues and knows how to resolve this, I'd appreciate the info.
Originally Posted by PNA
Thanks Howard. I'll revisit the manual and see what affect this may have.
Regards
Regards
Originally Posted by roctech
No ,I open the directions and read when i,m all done and there are several pieces left over, then you use the directions in reverse to disassemble.
I've never been lost, I was taking the scenic route.
