Aftermarket Amp Walkthrough
Wondering why there isn't a walkthrough with pictures for wiring aftermarket amp...I read through the threads but it's still a bit vague on how to pass through the back wall...any help would be appreciated
http://www.google.com/url?q=https://...h3AUp-455gu4dg
heres a link to a thread about hooking up a rear fog light. In post #9,pic 4 you can see the white wire going up by the seatbelt swivel. Theres a piece of tape over the wire but you can get the overall idea.
I also posted a thread called roll bars in a coupe that has some good pics on taking the back access panel apart. The guy who wired up my amp ran the wire through the box that contains thge cooling fan for the ecu, down thru the firewall...cabin filter if I remember, and along p/s kick panel thru the bottom part of the bulkhead.
Someone out there has better input than mine, anyone care to help?!
It is shown removed in the first photo.
If you pull back the carpeted area you will find a hole with a sponge plug in it, take out the plug and you will find a hole into the hatch area. This hole is shown in the photo below. It's a bit blurry but the hole is visible. Those wires go through another hole not visible in the photo.
If you take of the door sill and the trim that goes up the front and rear of the door.
usprb1976
Apr 4, 2024 04:57 PM
pioneer4x4
Mar 18, 2021 02:17 PM
Blackktieguy
21
Oct 26, 2015 12:32 AM
