Looking to Upgrade the Speakers...Thoughts?
Old Jul 19, 2011 | 06:38 AM
maxcichon's Avatar
Default Re: Looking to Upgrade the Speakers...Thoughts?
Originally Posted by dinasrt
Attachment 22676 Just received these recommended speakers today. So..... do these integrated tweeters take the place of the OEM tweeters or will I be listening to both? i.e., Do I disconnect the existing tweeters or leave them wired up?
I use both-but I never was impressed with the OEM ones in the upper doors. The (new) Infinity ones have much higher (louder) output.
Get them installed without the door panel-there is a little switch on the tweeters and you may want to play with that and Bass/Treble settings before you button it back up.
Do you have capacitors installed?
Old Jul 19, 2011 | 07:05 AM
jmk41's Avatar
Be sure to let us know what you think of these! I am in need of door speakers as well and not sure what I want to do yet.
Old Jul 19, 2011 | 09:04 AM
dinasrt's Avatar
Yes, I do. Do I still need them w/ the new speakers, or do I remove them? Thanks for the help on this.
And I will report about the upgraded sound (hopefully) soon.
Old Jul 19, 2011 | 12:20 PM
maxcichon's Avatar
Definitely keep them in. All you have to do is mount the speakers and wire them up.
Don't leave anything loose or it will rattle! Can't have that, now can we?
Old Jul 19, 2011 | 12:37 PM
dinasrt's Avatar
I hear that...... I mean, I don't want to hear that. I'll make sure everything is tightened down. I've helped my daughter line her doors w/ dynomat, maybe I'll do a little of that while it's open. Thanks again for the help. Bob
Old Jul 19, 2011 | 02:02 PM
joejones's Avatar
Originally Posted by syfi
I installed the Infinity Reference 6030cs. Bought off ebay. They were an exact fit. 2 ohm and 92db. Even left the OEM grills on.
Looked up the seller and he is out of them. But he has the Kappa 60.9cs which I would have rather had. Same install, direct fit
and much better sound, plus this guy warrants them for 2 yrs. and Free Shipping...!!
NEW INFINITY 60.9CS 6.5 CAR COMPONENT SPEAKERS+2YR WRNT | eBay
These are 6.5 X 6.75 - will that fit?
Old Jul 19, 2011 | 02:18 PM
maxcichon's Avatar
I've looked everywhere and only see drawings showing 6 1/2" diameter.
I'm sure they'll fit.
http://manuals.harman.com/INF/CAR/Ow...v14Mar2008.pdf
I just don't see where the "6 3/4" comes from unless it means a universal fit for 6 1/2 AND 6 3/4?
Old Jul 19, 2011 | 03:44 PM
joejones's Avatar
I was looking at what I think is the same speaker on Amazon.
Amazon.com: Infinity 609CS 270W (Peak) 6-1/2 x 6-3/4 Two-Way Component System Speakers (Pair): Automotive
Old Dec 30, 2012 | 08:00 PM
gp1200x's Avatar
I have been installing an Alpine CDE-HD137BT with a set of Infinity 60.9CS speakers over the holiday weekend. I am almost ready to test everything tomorrow after wiring it up for a four speaker system (609CS in front and stock subs). I followed the advice on this forum and added another set of wires to the amp for the subwooferss. I also used a separate connector for the speaker wires to the amp (8 wires total) so I can hookup the pre-amps or the HU speaker wire outputs to hear the difference - simple wire plug to swap sources. Radio shack had nice connectors that made it fairly easy.
Here are some gotchas......The 6 inch and the tweeters DO NOT FIT without mods. My brother modified the 6 inch which required some cutting of the plastic mountng pieces. They are not a simple plug and play due to slight speaker design changes which interfere with the two mounting pieces that sandwich the speaker. It is not a major problem but does require some rework.
The tweeters DO NOT FIT the stock mounting brackets. The 609CS tweeters are much heavier and larger in diameter. I used small cutting tools to enlarge the tweeter hole and mounted one of the supplied mounting brackets in it's place. It took me a few hours to do each one and epoxy all of it but it looks like it turned out nicely. Once behind the stock grille plates you would never know anything was ever done.
The last problem is the large Crossover. I have not yet determined whether I will try to mount it on the panel or the door. In either case it is a problem - it is large and has some weight to it. I used the stock 6 inch speaker wire and connector from the amp (just left the original tweeter wire unconnected and tucked away) and used the original 6 inch speaker wire connector to create a connection to the crossover. All the Crossover connectors and speakers (6 inch and tweeters) are simple bare wire connections which is somewhat nice however I still have to splice in a male/female plug for future door panel removals. I just can't figure out where the best place is for this Crossover. It also has a 0 / -6db switch which I haven't yet determined what it should be set to.
I still have to mount the BT mic, fix the squeaks behind my ear and see if I can tighten the window fits to cut down on wind noise!
This is NOT a one day job (more like a weekend plus!) and I am glad I had some help working on it. I just hope I have all the wiring correct since I spend a lot of time soldering all the connections - at least I still have everything apart for testing.
Old Dec 30, 2012 | 08:07 PM
gp1200x's Avatar
Here are some gotchas......The 6 inch and the tweeters DO NOT FIT without mods. My brother modified the 6 inch which required some cutting of the plastic mountng pieces. They are not a simple plug and play due to slight speaker design changes which interfer with the two mounting pieces tht sandwich the speaker. It is not a major problem but does require some rework.
The last problem is the large Crossover. I have not yet determined whether I will try to mount it on the panel or the door. In either case it is a problem - it is large and has some weight to it. I used the stock 6 inch speaker wire and connector from the amp (just left the original tweeter wire unconnected and tucked away) and used the original 6 inch speaker wire connector to create a connection to the crossover. All the Crossover connectors and speakers (6 inch and tweeters) are simple bare wire connections which is somewhat nice however I still have to splice in a male/female plug for future door panel removals. I just can't figure out where the best place is for this Crossover....and also has a 0 / -6db switch which I haven't yet determined what I should set it to.
And I still have to mount the BT mic, fix the squeaks behind my ear and see if I can tighten the window fits to cut down on wind noise!
deerhunter
Jan 16, 2021 10:56 AM
Sep 28, 2015 07:40 PM
ayebb
Sep 18, 2015 03:35 PM
RacerXofFL
Sep 15, 2015 05:00 PM
darf
Aug 26, 2015 06:41 PM
