Sony CDX-F7700 Install Pic
Old Aug 7, 2004 | 04:48 PM
David Burns's Avatar
Default
Originally Posted by MEXICANCROSSFIRE
I misundestood your question, the ashtray needs a little more than a gentle push to open, this controller requires very little pressure, so no, it doesn't pop out every time you hit a button.
Cool. Mine pops out pretty easy which is why I asked. I've got another project in mind and was curious. I may need to figure out how to lock mine in place.
And, I never thanked you for posting the pictures.
No prob. Just get the full URL to the .jpg, paste the URL into a message here. Then highlight the URL again and click the little "Img" button above the compose window.
So, I'm looking at a new set of door speakers, a 4 channel amp and a sub.
Questions:
What size are the door speakers (mid)?
Has anyone tried to fit a sub in the "box" behind the seats?
Sounds like the stock "crossover" is not very effectively splitting the audio to the various speakers. :cry:
Not sure on the speaker sizes (check DFWSBR's posts for a link to his 'replace the factory system" web site).
Keep in mind the "box" behind the seats houses the fuel tank.
Old Aug 16, 2004 | 09:48 AM
keijoh's Avatar
Default
Originally Posted by mhorn
It also has an Auxiliary input for iPods and such. If anyone is interested I bought it from sounddomain.com using their 105% price match. They also threw in the wiring harness for free.
mhorn - the auxilliary input is it located in the upper right corner or the rear of the unit?
Like the unit, think it might be my first upgrade.
Old Aug 16, 2004 | 10:51 AM
mhorn's Avatar
Default
It is on the rear on the unit. I ran the RCA-to-mini cable through a seam in the plastic on the side of the console inside the glove compartment. I can then just tuck the cable in to the glove compartment when I don't need it. I can take a picture if you would like to see it.
Old Oct 20, 2004 | 07:39 PM
DG's Avatar
DG
Default Re: Sony CDX-F7700 Install Pic
MEXICANCROSSFIRE:
I really like your setup. I am thinking of doing something similar, but without modifying the ashtray because I am on a lease. My one question is, with the Sony head unit, were you able to just connect the Belkin cable directly? I have read about people having problems with the RCA jacks on some Sony head units, with them not working without some kind of adapter. It seems some RCA jacks are non-standard with Sony.
Again, the install is very clean. I am thinking of making some kind of mount for the iPod that I can put in the slot in my center console (I have a base coupe with no cup holder). I'll route the belkin as you have and be able to see the iPod while I drive to change songs. Still haven't found any inexpensive mounting solution though.
Old Oct 20, 2004 | 11:53 PM
MEXICANCROSSFIRE's Avatar
The cable is plug and play, it's a standard minijack to RCA cable.
I'm sure you'll figure something out, but you could always buy the ashtray and store it so you can return your car when the lease is up.
MiamiTVR
Jan 30, 2016 02:15 PM
steps
Sep 3, 2015 07:24 PM
velociabstract
Aug 7, 2015 01:30 PM
mattnelson71
Jul 28, 2015 12:52 PM
