factory amplifier
Old Dec 26, 2011 | 04:22 PM
jediracer's Avatar
Default factory amplifier
New project underway. Need to understand a few things. Does the factory amp have rca jacks? If the answer to the previous answer is no; where is the best place to cut wires to install rca connectors in order to use the rca outputs from the HU. I appreciate the help!
James
Old Dec 26, 2011 | 04:56 PM
Default Re: factory amplifier
I use the RCA outputs from my Alpine HU - it's done with the Crutchfield adapter cable ...
( Same for the Sony HU I also have )
Old Dec 26, 2011 | 11:52 PM
BrianBrave's Avatar
<--- Huge Horsepower
James
No - you will have to splice the factory wiring harness in order to solder in some RCA jacks.
Old Dec 27, 2011 | 01:56 PM
jediracer's Avatar
I understand the splicing part. Now the question is: where can I splice? Do I have to expose the amp and do it there; or can I just be between the amp and HU connector?
Old Dec 27, 2011 | 03:47 PM
Mrmiata's Avatar
https://www.crossfireforum.org/forum...-problems.html
See if this helps you out.. plug at the stereo.
syfi
Mar 28, 2026 04:14 PM
blackpepper
Dec 18, 2021 06:17 PM
UNDER PSI
Nov 1, 2015 09:39 PM
livefreeordie
Sep 22, 2015 08:13 PM
Idrenak
Sep 19, 2015 08:17 PM
