bad crossfire radios
Old Dec 16, 2014 | 05:25 PM
gerry44's Avatar
Default bad crossfire radios
My car is standard convertible the sound from the radio leaves a lot to be desired. So would replacing the radio help? I prefer not to tear the doors apart so I am looking to add a speaker on the hooks between the 2 seats on the back panel I would have to run a wire from the radio to the speakers I would want to tap the left door speakers. What color wire goes to the left door and is there a better way to tap that wire. I assume all the radios wires are wrapped in a loop in the car, an ideas?
Old Dec 17, 2014 | 01:26 PM
meh03's Avatar
Default Re: bad crossfire radios
A new stereo will help a lot. Especially if you go with one with HD radio.
Old Dec 17, 2014 | 01:56 PM
DTMenace's Avatar
gerry44
Before you start spending big bucks, try the "FIX" that is proven in the link below. It will cost you $2.00 and a little time.....
Dennis
DTMenace
https://www.crossfireforum.org/forum...-buck-mod.html
Old Dec 17, 2014 | 04:56 PM
gerry44's Avatar
I just read the forum on "caps" maybe I am stupid but I can't figure out what they mean. However, I will start looking for a HD radio as you suggested.
Old Dec 17, 2014 | 05:41 PM
Mrmiata's Avatar
They block the lower frequencies so your door speakers don't "muddy" so to say from it. Higher volumes it makes a nice difference.
Old Dec 17, 2014 | 05:52 PM
gerry44's Avatar
yes, I went further into the post and found what I was looking for How to hook up the caps and where to buy them......................Great! Will do!
Old Dec 18, 2014 | 12:19 AM
Hummm, I've never had anyone tell me they got a considerable difference in sound quality between the OEM radio and a replacement. Add to that, the tight confines of a roadster doesn't lend itself to the acoustics of a coupe.
Old Dec 18, 2014 | 09:57 AM
mobilefitt's Avatar
"Caps" or capacitors can be found at radio shack or other electronics store. They do make a considerable difference, however, in an older car, the "subs" or sub woofers will receive a greater amount of frequency blocked by the "caps". This can lead to blown "subs" very quickly. (it did in my case) but I am in a 10 year old car. Do yourself a favor, If your serious about your sound system, ( I thought I wasn't until I got started working on it), go ahead and get a decent head unit..... One that doesn't cut off for no reason driving down the road..... Get something with Aux input, and/or BT. Marine Radio's tend to be the same color as our trim. Door speakers are of excellent quality, but the subs are like unicorns. If you want to keep it simple, find a core set of Subs and have them re-foamed.
The stock amp can be wired to make a decent head unit sound a lot better!
BTW. I have stock subs that need to be re foamed. PM me if you want to be pro-active and have a set sent for repair so when your subs give up, due to time and carrying the extra load from the "caps". I'll let them go for a fair price and ship them to the repair station of your choosing.
Old Dec 18, 2014 | 04:38 PM
Mrmiata's Avatar
Can you show me where your information came from that indicates blocking the sub frequencies from the door speaker overloads the rear subs? After two plus years I must have super subs since they are working just fine.
Old Dec 18, 2014 | 05:04 PM
gerry44's Avatar
I got the caps and will put them in (cheap fix) if it works man at radio shack said it should also. I will do this before I go out and buy a new radio Again mine is a coupe so there are no rear speakers just in the door which is where I will put the caps on the black wire like post 21 says. Now reading more of the posts, I want to make sure I got the right cap. The one I have is 220uF 35v it has 2 wires coming out of 1 end of the cap. Looking at post 21 it looks like it shows 100v 220uF cap. Will the one I have work?
Old Dec 18, 2014 | 05:16 PM
Mrmiata's Avatar
"Base" models were the only ones without the subs.. Coupe's that are Limited or SRT6 have subs.. haven't looked for what you have.. but ALL 04 models are "Limited" models since base versions came out in 05 I believe it was. Move your seat forward and look behind them for the subs in the divider wall.
Old Dec 18, 2014 | 05:48 PM
You have an '07 Roadster, so like MrM said, the subs are behind each seat in the bulkhead.
Crank the radio all the way up and put your hand on them.
Old Dec 19, 2014 | 08:01 PM
mobilefitt's Avatar
2 months after doing my caps, both stock subs have deteriorated. They are available as cores currently. Both need new foam and buzz obnoxiously when connected in the car.
Obviously they hit when the base is turned up and the caps filter the door speakers.
Old Dec 20, 2014 | 11:20 AM
gerry44's Avatar
After reading all the great posts and talking to a tech I know I am going first put in a HD radio. I talked to Crutchfield and they made a recommendation not the most expensive then they would supply all the parts needed to put the radio in. Crutchfield also said there may be a speaker risk by using caps so HD first then I'll go from there. I do appreciate all the posts on this issue.
mhajek18
110
Sep 6, 2019 01:04 PM
BEATv1
Jul 16, 2015 09:40 AM
BEATv1
Jun 12, 2015 05:20 PM
Kv1ck
Jun 8, 2015 07:25 AM
MJPowers
Jun 8, 2015 02:34 AM
