Omg freaking skreem
Old Mar 31, 2020 | 10:36 AM
Steel Possum's Avatar
Default Omg freaking skreem
I had one that went bad about 3 weeks ago.
Not a happy camper. They’re apparently on backorder until August and I’m literally losing my <expletive> mind.
anyone know of any good finding places/have one stockpiled that I can buy?
thank you!
Old Mar 31, 2020 | 10:57 AM
Default Re: Omg freaking skreem
Try these guys, we have reports of success with them :
https://www.precisionecu.com/search?...t&q=crossfire*
Old Mar 31, 2020 | 11:01 AM
SOS Diagnostics can repair them
Old Mar 31, 2020 | 11:09 AM
interesting. Will they be able to fix it if it is bad?
I’ll have to look into that. I was thinking the thing was probably fried.
Old Mar 31, 2020 | 05:49 PM
If you want to delete the immobilizer click below to Ebay but realize the key FOB will only hold the key to open the door as there is no more remote or security if you go that route.
2004-2008 Chrysler Crossfire ME2.8 Immobilizer Delete / Plug n' Drive
Old Mar 31, 2020 | 06:48 PM
SOS will get you running again and not compromise your key fob from working and your security system is still functional
S.O.S. Diagnostics
Old May 12, 2020 | 01:40 PM
One last question: the part number on the SKREEM is a Mercedes part number. If Mercedes has the SKREEM it would work in the crossfire, right? In other words... there isn’t any nofty programming I need to be cognizant of that would prevent it from working, right?
Old May 12, 2020 | 02:54 PM
NO! IT WILL NOT work!
Old May 12, 2020 | 03:19 PM
The key, ECU and screem must all be programmed to work together. Mercedes will not or can not program for our cars.
Old May 12, 2020 | 03:23 PM
for the record: I understand that it has to be programmed to work with the ECU... but just want to make sure. Even if it is the same part number it won’t work? (And do we know if anyone else has tried this?)
Old May 12, 2020 | 03:25 PM
totally. The idea that I have is to buy the part and have someone program it. So that’s the question is that if it’s the same part number but coming from Mercedes... can it be programmed for a crossfire <by some third party>
Old May 12, 2020 | 04:46 PM
The only company that I know of right now that can repair or replace a Crossfire screem is SOS Diagnostics. Give them a call and ask.
Old May 12, 2020 | 11:38 PM
Scott M's Avatar
Steel Possum-- no sense in buying a new SKREEM, your old one just needs to be re-programmed or whatever SOS does to it. They don't fail physically, something goes haywire with the programming.
Old May 13, 2020 | 04:34 AM
Viper-666's Avatar
This could be possible but the ROM (the part of the processor you can't change) are a litte bit different. I don't know if this is a issue. I think it would work because I have tested a Set (skreem, keys and ecu) from a Mercedes SLK 320 (R170) and I can start my Crossfire.
But I have to dig deeper in that to confirm that it would work.
Old May 19, 2020 | 12:42 PM
mariontr's Avatar
Well, SKREEM went off today and skreem for a couple of minutes before going off by its own. Does anyone know what might be the issue, nothing touch the car or hit it in anyway. I started the car and opened the hood and it was skreeming, shut it off then it got lower in skreeming and went off.
Old May 19, 2020 | 01:41 PM
mariontr's Avatar
Ok, found the other threads on looking for water in trunk area, will do that this weekend as the weather in south florida at the moment is up for grabs this week as heavy showers are passing through the area this week. So could be the deluge of water that we have gotten that set it off today. I did find that moving the 10 fuse, manual close driver's door but have to manually push the button to close passenger door but nothing to lock the trunk, so unlocked at the moment in the driveway but will lock it later tonight in the hopes that SKREEM does not re-emerge
Old May 19, 2020 | 02:45 PM
Do you know the difference between the SKREEM and the siren?
Old May 19, 2020 | 05:22 PM
mariontr's Avatar
Yes but I just put the two together
Old May 19, 2020 | 05:32 PM
Your problem is bad batteries in your alarm siren. Your skreem controls the ability of your car to start. Do a search for alarm siren and you will find your problem. Your siren will cost about $150.00 if you change it yourself and the skreem in the neighborhood of $700,00 if you do it yourself. I suggest using this site to familiarize yourself with your car. If you click on the link in onehundred80s signature you will learn much if you take the time.
Old May 19, 2020 | 05:43 PM
mariontr's Avatar
Thanks ZERACER, I will order the siren and hopefully it is not the SKREEM as well. I saw posts where NeedsWings maybe the cheaper option for the SKREEM.
Jocko124
Jun 4, 2018 10:14 PM
mophreakous
20
Aug 20, 2010 10:36 AM
Holycrap
Dec 31, 2009 09:53 PM
DanielNTX
Aug 31, 2007 09:30 PM
Wildbill
Feb 3, 2005 03:25 PM
