Relay Control Modules part numbers
Old Nov 5, 2020 | 06:33 PM
Jim Holian's Avatar
Question Relay Control Modules part numbers
Gentlemen - I've noticed that some used RCM's are numbered A 170 545 00 05 and embossed is Germany on the case. I've seen others numbered A 170 545 01 05 and embossed is Hungary. Note the 00 05 and the 01 05 and the two different countries. Is there a difference in the operation of the two parts? Are they interchangeable? My car is a 2005 Limited Coupe with the NA engine and auto trans. I want to get a spare RCM that is correct for my car. Any thoughts on the two different part numbers and their application?
Jim
Old Nov 5, 2020 | 08:43 PM
Default Re: Relay Control Modules part numbers
allmost all the RCM's I've seen were A 170 545 03 05
Old Nov 5, 2020 | 09:14 PM
Ronman's Avatar
Jim
The part numbers you listed are for the pulse module NOT the rcm. You need to learn the difference between a pulse module and a rcm or what one actually looks like. The part number ala_xfire gave you is correct for the actual rcm.
Old Nov 6, 2020 | 10:14 AM
Jim Holian's Avatar
Ronman - If you look up "Chrysler Crossfire relay control module" on ebay you will see what I'm talking about. They are all either 00 05 or 01 05. There are NO 03 05's on there. Shopping for a RCM to re-solder shows nothing like what you referenced.
Jim
Old Nov 6, 2020 | 10:57 AM
Of course E-bay can't be wrong. Those numbers all appear to be RCMs
Old Nov 6, 2020 | 01:58 PM
Jim
Then splain this Lucy :
Old Nov 6, 2020 | 02:47 PM
My bad, you are correct. My point was just because something comes up on an E-bay search does not make it so.
charlesdsmith
15
Apr 1, 2016 11:59 AM
XF Tom
Aug 28, 2013 08:12 PM
brhertel
Sep 15, 2011 07:15 PM
cszkalak
Nov 11, 2010 05:03 AM
typhoon55
Feb 1, 2005 09:38 PM
