Crossfire radio color code identification. Help
Old Dec 16, 2020 | 12:22 PM
Romad's Avatar
Default Crossfire radio color code identification. Help
I looked at the "Sticky's" and read what was posted. Seems the Sosche harness that the Red and Blue wires are reversed for aftermarket installation. That being said, does anyone have a Sosche color code, by color identification. The wires are multi-colored and the after-market adapters are solid colors. Like to know the function of each Sosche muti-colored wire. Thanks
Old Dec 16, 2020 | 12:40 PM
Default Re: Crossfire radio color code identification. Help
  • Yellow – 12V Constant
  • Red – 12V Accessory
  • Black - Ground
  • Black with White Stripe - Amp Ground
  • Blue - Power Antenna
  • Blue with White Stripe - Amp Turn-On
  • Orange – Dash Light Dimmer/Illumination
  • Green – Left Rear Speaker (+)
  • Green with Black Stripe Left Rear Speaker (-)
  • White – Left Front Speaker (+)
  • White with Black Stripe – Left Front Speaker (-)
  • Purple – Right Rear Speaker (+)
  • Purple with Black Stripe – Right Rear Speaker (-)
  • Gray – Right Front Speaker (+)
  • Gray with Black Stripe – Right Front Speaker (-)
Old Dec 16, 2020 | 01:20 PM
Romad's Avatar
  • Black - Ground
Thank you for your quick response and is just what I needed. When the color says amo ground and "amp" turn-on I assuming that to me the ground and turn on are for the "radio" I'm installing. Correct? Lot of people do install an additional amplifier to drive big speakers.
Old Dec 16, 2020 | 01:23 PM
Romad's Avatar
Thank you for your quick response and is just what I needed. When the color says "amp ground" and "amp" turn-on I assuming that to me the ground and turn on are for the "radio" I'm installing. Correct? Lot of people do install an additional amplifier to drive big speakers. Just a difference in terminology I'm guessing.
Old Dec 16, 2020 | 05:11 PM
No, they are for the amp ( located in the passenger foot well ). Here's the radio wiring in the car :
( the wire in pin 5 of the car side connector )
Old Dec 16, 2020 | 05:33 PM
Romad's Avatar
REALLY! I had no idea as I've only had my car a little over a month. The Mercedes radio volume control was not working properly so I bought a new radio with bluetooth.
Old Dec 16, 2020 | 08:56 PM
If you have a base model or a SE ( Special Edition ) model, there is no amp and the above schematic does not apply.
If your seats are cloth, it's a base/SE
Old Dec 16, 2020 | 09:09 PM
Romad's Avatar
I think mine is a limited edition. Electric leather seats, electric windows and automatic trans. Does that make it a Special/Limited edition? I added a Bently style grill and tinted windows.
Old Dec 17, 2020 | 10:52 AM
It is a Limited edition, all the 'Special' editions were red roadsters.
Razboy
Aug 10, 2014 10:22 AM
Philco
Oct 16, 2013 02:50 AM
austinboyette
Aug 10, 2011 09:54 PM
huntsmcgee
Oct 3, 2010 03:14 AM
Roy Mander
Sep 23, 2009 08:55 AM
