head unit wire harnesses tight fit
Old Jul 30, 2021 | 02:13 PM
nation99's Avatar
Default head unit wire harnesses tight fit
Can anyone tell me the easiest way to access the area behind the head unit? I need to be able to position the wire harnesses so that they are not in the way of the head unit sliding fully into place.
Thanks, Dave
Old Jul 30, 2021 | 05:25 PM
Default Re: head unit wire harnesses tight fit
Thanks, Dave
Am thinking you mean the stereo? You need the radio removal keys to insert them into the thin slots on the lower left and right bottom corners of the unit. IF it is an aftermarket radio I cannot help you. Good luck!
Old Jul 31, 2021 | 01:33 AM
JSK's Avatar
JSK
I have changed radios four times and never had a problem getting one in. If my memory serves me correctly I always stuffed the harness and connectors at the back of the radio but also below it.
Old Jul 31, 2021 | 02:34 PM
nation99's Avatar
Thanks, I think if I could get at them I would be able to tuck them under or above the radio. I'll keep trying.
Old Jul 31, 2021 | 02:44 PM
JSK's Avatar
JSK
There is a plastic shelf under the radio, if I remember correctly you must push that bundle of stuff past that shelf and down.
Old Jul 31, 2021 | 04:16 PM
nation99's Avatar
That is exactly what needs to happen. Maybe I can try to work a small plastic trim tool past the radio and push them down. Thanks again.
Old Jul 31, 2021 | 08:36 PM
Can you re-route those cables around that rear bracket? As many times as I have had my radio out, it was very easy to preposition the cables so they weren't in the way of any obstacle. Good luck!
simmie777
Jan 31, 2011 10:51 PM
UK DAVE
U.K.
Jan 22, 2010 04:46 AM
ryan48
Nov 30, 2008 04:05 PM
bucks7
Jul 24, 2008 01:00 PM
tom2112
Oct 2, 2007 04:55 PM
