Speaker repair kit
Old Mar 25, 2022 | 04:45 PM
nickwe21's Avatar
Default Speaker repair kit
Hi guys!
​​​​​​REar subs are just buzzing and same with two of the door speakers. Is there a kit I can order? I'm assuming it's the brittle rubber ring inside cause that's usually what happens.
any tips would be helpful or what kit to order.
Thanks for all help and have a great day.
Nick
Old Mar 25, 2022 | 06:07 PM
DeKalb's Avatar
Default Re: Speaker repair kit
I used a kit from Springfield Speaker Repair ... instructions were easy to follow and results are very good ... am very please with the product, instructions, and final repair
Old Mar 25, 2022 | 07:00 PM
nickwe21's Avatar
What kit would I order? And how many speakers does it fix? All of them? Thanks for your help with this.
Nick
Old Mar 25, 2022 | 07:51 PM
DeKalb's Avatar
Go to the Springfield Speaker Repair site ... the kit is for Infinity Speakers, it might be listed under Crossfire ... it will fix 2 speakers, the Sub-Woofers behind the seats ... they have kits for the door speakers also ... the site is easy to find what you need
Old Mar 25, 2022 | 08:01 PM
dcskmail's Avatar
Ebay $24 with shipping
https://www.ebay.com/itm/302700733219
Old Mar 25, 2022 | 11:01 PM
nickwe21's Avatar
Just ordered the kit.
Now here is the thing. On both doors, the small speakers don't work at all and the subwoofers behind the seat don't work either. I know the subwoofers will be fixed with the kit but what could cause the little speakers (see picture) to malfunction? Same issue as the subs and a kit could fix?
Thanks for your input guys.
Nick
Old Mar 25, 2022 | 11:14 PM
UrbanE's Avatar
Don’t waste your time repairing them
just get a new set. You’ll be super happy you did. Plug and play, no messing around with old speakers.
when they finally break down, they’re trying to tell you something
”REPLACE ME”
Old Mar 26, 2022 | 10:23 AM
Are you sure the tweeters in the door are getting the signal? Also, check tweeter coils with an ohm meter (make sure at least one wire is 'unplugged' from the tweeters). If a wire 'broke' or the coil 'opened', that could be your issue. Good luck!
nickwe21
Feb 27, 2022 05:44 PM
rayludwiczak
Sep 3, 2019 09:06 PM
the.Santorini
May 11, 2015 04:28 AM
07n/awetdream
Feb 1, 2015 11:38 PM
saldous
Jul 18, 2004 10:52 AM
